TriStar Price differences
Discussion in 'Multihulls' started by eiasu, Dec 17, 2013.
  1. eiasu
    eiasu Junior Member
    Hi everybody,
    I cannot understand this huge price difference comparing the price of these 2 ads of TriStar Trimaran:
    S/V ¨Beachouse" Tri-Star 60'- Year 1984 - Trimaran-
    Designed by Ed Horstman / Build in Texas by Beach Boats Builders of Port Bolivar.
    Available in Rio Dulce
    Asking US$ 695,000
    and the other:
    1987 Horstman 50 Tristar $115,000
    Another ad of the same boat
    Looks like the second one is home built and in a not so good conditions, but it is reasonable such a huge price difference?
    Ciao, thank you
    Eiasu
  2. redreuben
    Likes: 285, Points: 83, Legacy Rep: 349
    redreuben redreuben
  3. Stumble
    Stumble Senior Member
    The 60' was built by a major boat yard with a good reputation and used foam-fiberglass core construction the 50' was built by "certified boat crafts man, used only top quality materials"
    The bigger one is 10' bigger
    The 60 has a brand new engine (100hrs) vs the 50 with 350hrs on the original (30 year old) engine
    50 -120gal diesel, 60-600gal diesel
    Basically the bigger one looks like a custom commercial build, and the smaller looks like a home build with an unknown history. I might lean towards the smaller one, but if an see the issues of it.
  4. cavalier mk2
    Likes: 143, Points: 63, Legacy Rep: 214
    cavalier mk2 Senior Member
    You'd want to check materials used on the 50 before making an offer. There was a unfinished 50' made of CDX ply in a yard in Napa for some time. Adequate considering the scantlings for skins if everything is well sealed but beams at least should be marine and the more the better. Norm Cross tried to get everyone to use marine on the outer skin, these boats are double diagonal planked which is strong. The older the construction the better if CDX was used as the quality was better way back when.
  5. upchurchmr
    upchurchmr Senior Member
    There have been reports of 60's and 70's eras home builts which simply fell apart due to poor ventilation trapping moisture inside.
    The 70's plans I have talked about removing plywood structure with your hands like tearing sheets of paper.
    There may be a very good reason for the lower price. get an inspector if you are serious.
  6. cavalier mk2
    Key word for a wood boat is ventilation. Very long life if they get it with much better performance through stress cycle fatigue than fiberglass.
  7. redreuben
    redreuben redreuben
    Key word here is fibreglass, the 60 is foam sandwich and the 50 is described as fibreglass.
    Just sayin'
  8. cavalier mk2
    9 out of 10 sites tend to list ply covered with glass boats as fiberglass so checking is an idea. just sayin.....
  9. redreuben
    redreuben redreuben
    Really ? Thats stretching the truth just a bit !
  10. cavalier mk2
    Not by much, maybe we should count them. 5 out of ten sound more realistic? To be fair it is usually mentioned somewhere but I think they want to get people looking first. It is advertising.....
  11. upchurchmr
    The actual description said 3 plys of 9oz fiberglass over 2 plys of 1/4" plywood.
    Personally I don't know where to get enough people to go sailing with "6 queen sized beds"
    Sounds more like a floating hotel.
    I looked at a Cross about the same size about 30 years ago. It had so much interior volume it scared me to think about upkeep.
  12. redreuben
    redreuben redreuben
    Ah full description !
    Fir plywood ! And therein hangs the tale !
    There is your price discrepancy, fir plywood v foam sandwich + 10'
  13. cavalier mk2
    Ha! The hint is just saying fiberglass, Tristars and Cross designs are either ply or foam core. If it has the foam core layup believe me they say it up front. If it is the ply it is listed as fiberglass. Too bad as a good ply boat can be great.
  14. cavalier mk2
    Now what grade of fir? Marine, AC,.......CDX?
  15. upchurchmr
    Cavalier,
    The description is in the ad posted.
