Trim axis of planing boat.
Discussion in 'Boat Design' started by Henry Swanepoel, Apr 16, 2018.
  1. Henry Swanepoel
    Henry Swanepoel New Member
    About which axis or point does a boat trim when planing? Is it simply the CG or is it some other point?
    And am I correct in stating that when the vessel is static, the axis about which it will trim when mass moves on the vessel is the centroid of the water-plane area?
    Likes: 2,267, Points: 123, Legacy Rep: 2031
    It gets more complicated when planing. The dynamic lift is dependent of shape and speed. It shifts with speed as the boat rises up on a plane because the shape and total surface area submerged change.
    fallguy likes this.
  3. daiquiri
    When planing, the static trim will be determined by the equilibrium of all the external non-inertial forces (hydrostatic, hydrodynamic, aerodynamic, mass) and moments around the CoG.
    I realize that the above is essentially a tautology, but is hard to say anything more than that without getting into the design details of the vessel.
  4. Heimfried
    Likes: 153, Points: 43, Legacy Rep: 37
    Heimfried Senior Member
    That's right, but just a small trim changes the locus of the centroid of the water plane. So the next incremental trim motion has an slightly different axis and so on.
