Triloboats
Discussion in 'Boat Design' started by charlesakeem, Jul 27, 2011.
  1. charlesakeem
    charlesakeem Junior Member
    http://triloboats.com/
    What are your thoughts on the Triloboat series of boats.
    They seem perfect for someone looking to build a a relatively cheap live aboard.
    The entire concept of using whole uncut sheets of plywood for build times from a week to 3 months does make sense from a construction speed standpoint if you're willing to let good enough be.
  2. frank smith
    Likes: 14, Points: 28, Legacy Rep: 185
    frank smith Senior Member
    They look like wooden house barges. I would like standing head room.
    Why the are the front and back different ?
    Not sure that it is too hard to cut a piece of plywood .
  3. Nurb
    Likes: 6, Points: 0, Legacy Rep: 82
    Nurb Junior Member
    What body of water are you boating on Charles?
  4. charlesakeem
    florida i where i currently am, planning on settling for awhile on various Caribbean shores
  5. Tad
    Likes: 184, Points: 73, Legacy Rep: 2281
    Tad Boat Designer
    The Triloboats look great but I doubt they are intended for ocean passagemaking. The designer/builder is in the Alaskan Panhandle archipelago, where shelter is almost always less than 20 miles away....which could be called semi-protected waters.
    If I was building a barge for ocean passages I would include some full bulkheads to minimize wracking.
  6. FAST FRED
    Likes: 109, Points: 63, Legacy Rep: 1009
    FAST FRED Senior Member
    Plan on getting one of these to the Carib as deck cargo.
    FF
  7. eyschulman
    Likes: 8, Points: 18, Legacy Rep: 77
    eyschulman Senior Member
    If you get a NA. to draw up plans for a stich and glue power cat using ply sheets with devloped surfaces keeping hulls long and narrow light and low center of gravity you might have a boat that will work for you. Not cheap and not over night build.
