Time before de-molding
Discussion in 'Fiberglass and Composite Boat Building' started by burke, Mar 9, 2017.
  1. burke
    Likes: 1, Points: 8, Legacy Rep: 16
    burke Junior Member
    Have done a 3 x 7' crowned composite panel (1" balsa core) using poly resin at 60 degrees. Others have said to keep it on the form as long as possible before removing to minimize distortion/racking/etc. I'd like to remove it at day # 5. OK?
    Thanks
  2. Sparky568
    Likes: 4, Points: 8, Legacy Rep: 10
    Sparky568 Junior Member
    Constant 60 degrees and right amount of catalyst for the temp you should be fine. How many layers of what either side of the balsa?
  3. burke
    burke Junior Member
    1708 Biax/mat side 1,
    mat/bix/mat side2
  1. Bigtalljv
  2. Boatface
  3. metalsailer
  4. Mardonis
  5. burke
  6. midcap
  7. jiggerpro
  8. Jetboy
  9. kpiazzisi
  10. cando2
