Thrust bearing block
Discussion in 'Boat Design' started by Wayne Kendall, Aug 16, 2012.
  1. Wayne Kendall
    Wayne Kendall Junior Member
    Hello
    To keep my engine low I am using 2 universal joints joined by a short stub shaft, with a thrust bearing block. My question - What should be the operating temperature of that thrust bearing?
    Thanks
    Wayne
  2. keysdisease
    keysdisease Senior Member
    Whatever the manufacturer specify's as operating temp range.
    Steve
  3. Petros
    Petros Senior Member
    Typically, if it is directly attached to the engine, at continuous full throttle the crankshaft should not get hotter than about 200 deg F. If the cooling system overheats it might get a bit higher (like 40-50), but not much more before the engine stops running.
    MOst of the heat of a thrust bearing however would come from internally generated heat from the bearing friction. The better the quality of the bearing the lower the temp caused by frictional heating. IT is also important that the area around the bearing be considered for heat dissipation, either with good ventilation or cooling by conduction through the mounts.
  4. gonzo
    Likes: 2,298, Points: 123, Legacy Rep: 2031
    Oil bath bearing work at lower temperatures and can have a cooler incorporated. The bearing manufacturer specifies what the maximum temperature is.
  5. CDK
    CDK retired engineer
    The fact that you asked that question already says something is wrong. The thrust bearing is a permanently lubricated, sealed ball- or tapered roller bearing that has very little friction so it will get lukewarm only. If yours is too hot to touch the bearing races are damaged or the alignment sucks.
  6. Wayne Kendall
    Thrust Bearing Temperature
    The thrust bearing block that I have in my boat is fairly old. I just recently took it out and poured new babbit because the shaft had a fair amount of play in the thrust block. I also checked the ball bearings, in my case there are 2 sets both enclosed in 2 collars, which slide over the shaft. They appeared to be moving freely and intact. Separating the bearings is another collar with 2 set screws. My alignment seems to be okay, however, the block do get hot after running for a couple of hours. Is it because I poured new babbit which makes a tight fit on the shaft that causes the bearing to get hot.
    Wayne
