these turbine alternaters are easy to make
Discussion in 'Propulsion' started by Boston, Apr 1, 2009.
  1. Boston
    Boston Previous Member
    actually flywheels are the most efficient form of energy storage known
    and they are silent when run in a vacuum on magnetic bearings
    as for safety they are a time bomb just waiting to go off
    imagine over several million foot pounds of energy in motion say 10,000 rpm at 3' diameter and 200 lbs
    that thing would demolish everything it hit for about five minutes before it even thought about slowing down
    not safe at all brother
    thats the problem with em
    they're a time bomb
    and no I have most of the resources I would need to machine em out myself
    its the materials is all Ild need to spring for and thats dirt cheep
    hell I can do em out of titanium if I want to go for higher rpm's but Ill stick with under 20,000 rpm and go with chrome molly
    its cheep and strong enough
    eats cutting heads though
    the basic answer to your question is that if there were a way to deal with the gyroscopic tendencies toword axial stabilization
    then it would work fine
    for instance in a wave piercing design
    but in a design meant to roll with the seas you would be wasting valuable energy every time you played with the moment of rotation
    or whatever thats called
    Mas
    I already did that and Im sure I got it close but I still come up with about 42 tons displacement
    Im building a scale replica to keep me amused till I get things rolling and so I already have the sections copied to graph paper
    waiting glass for my new modeling table as I figured I might as well start out with a bomb place to do the model
    cherry framework under a piece of 3/4 inch etched and edged glass
    Ill cut the lower edge dead straight and use it as a T guide for the drafting part and then hook a piece of homosote over it for the building part
    its got to be ballast
    I just cant think of anything else it would be
    Im just going to call the guy who has one for sale and ask him
    ps
    that last picture is of the exact lines I have with the slight barrel back to it
    its a 1928 model
    Im debating keeping or loosing the barrel back
  2. rasorinc
    rasorinc Senior Member
    Bos, where did you come up with 7,000 BF? That is also 7,000 LF of 2 x 6.
    Are you going to crib frame it like the Ark? Best, Stan
  3. Boston
    traditional plank on frame
    I got the scantlings for it and worked up an estimate from there
    maybe I screwed it up
    Ill go check my numbers again but I cant be that far off
    and no
    board feet and lineal feet are two completely different animals
  4. masalai
    masalai masalai
    Boston, usual position (D.A.), so - if you are NOT sailing, why permanent ballast? - OK if it is temporary (water) ballast when fuel and other stores get low, so as to hold lines & designed efficiencies - new thing for me in relation to mono power when "hull speed" is all that is desired....?
  5. rasorinc
    60' long by 10' high = 600 X 2 +1200 LF + transon 15' x 10' + 150 LF
    adds up to 1,350 BF of 2 x 6 x 2 or 2,700 BF + another 150 total 2,850BF so if you double plank it in 2 x 6 you have 5,700BF. Your wood count is off base. Best, Stan
  6. Luckless
    Likes: 7, Points: 18, Legacy Rep: 105
    Luckless Senior Member
    Really? And just how long can you store the energy, and how much are you spending on it? I know they look great on paper, but there are many, many problems with current ones.
    I've only ever seen existing ones that are designed for short term, high energy storage, acting more as a buffer than as a 'battery'. Something between a capacitor and a storage cell. Are there ones that actually run well on magnetic bearings that are permanent magnets? The few I've worked with (For massive machinery) used a high powered electromagnet baring to be properly balanced.
  7. Boston
    and no
    W Oak
    ribs
    1860 board feet ( +20% ) average free board of 6' + 13' beam = 25' each at the widest point at 1 1/4 x 1 1/4
    keel
    550 board feet ( actual 475 ) 4.5" x 18" average height over 68'
    stringers
    200 board feet ( + 20% )
    bilge clamp
    120 board feet ( actual )
    bilge keel ( not sure I need them but Ill add it in for now ) 4"x6" x 60'
    240 board feet
    3 keelson's not actually necessary but we used to do it all the time
    360 board feet ( actual )
    garboards
    150 board feet ( + 30% )
    floors 300 board feet ( actual)
    beems and carlins
    500 board feet ( actual )
    shelves and clamps
    160 board feet ( actual )
    white oak 4,140
    and just for fun I went way overboard on those estimates
    only thing I think I missed was the knees and I can go them out of scraps
    ok I missed the 4x4 frame to the wheel house and a beam or two also in the wheel house area
    red ceder
    1600 board feet if I went with the 5/4 planking they had on it 26x50
    but Im kinda silly about building heavy so Im going with 8/4 so x 1.75
    and call it
    2,800
    cherry exterior
    decks 5/4
    600 board feet ( + 20% )
    wheel house raised panel
    1000 board feet 4/4 ( + 30% )
    aft cabin house
    cherry
    2,600
    4140
    2800
    2600
    9,540 board feet if I really try and waste wood
    at an average weight of say 3.1 lbs per board foot = 29,574 or 14.8 short tons
    I could throw another say thousand feet in of WO and Cherry and still only be at way less than half of what this thing is supposed to weigh
    oh and I forgot the cherry railings and guard rails
    doesnt mater weight doesnt add up no mater how you look at it
    its miles from the 42 tons displacement I get when I calculate for volume displaced
  8. rasorinc
    In 2 x 6 BF and LF are the same, It just seems like a huge amount of wood.
    Hard to believe there is that much in it from the picture. the 2 x 6 are nominal dimensions
  9. Boston
    Stan
    you are so right
    I completely read that wrong
    my bad
    I posted some numbers and although I went way overboard on it I was trying any way I could to come up with 42 tons
    Im thinking old Roby used to always say add up the wood and double it and you should get about the displacement after you add all the engines and such
    so if I can get the hull materials to weigh in at 21 tons then it will all make sense but its not even close
    flywheels
  10. rasorinc
    Your estimates on wood are equal to a 3,000 sq. ft. wood floor home with 1 x 6 cedar siding and standard 16" on center framing. I just cannot believe there is that much lumber in that boat. It is unreal to me. Not saying you are wrong maybe telling myself never estimate lumber in a boat. Best, Stan
  11. Boston
    oh I overestimated
    I went with largest dimension frame and for all frames and widest point on each beam for all beams
    same on decking with only the beam and length considered and not the shape
    same on all cabin house paneling and that keel is kinda hefty at 4.5 x 18 over the full length including the stem area
    although the ribs Ill probably enlarge from the called out numbers of 1 1'/4 x 1 1/4 since I enlarged everything else
    Ill work it all out and pay someone to check it before I start buying but
    I definetly overestimated
    what its showing me is that I did something wrong in one of two things
    displacement or ballast
    cause the rule of thumb old Roby used to use was always high
    displacement hardly ever equals twice the hull weight
    so either that hull has ballast or I calculated the displacement way wrong
    and Im pretty sure I got it right
    frankly Im ok with ballast but its kinda a surprise
    if I have to ballast that thing Im putting a huge brew kettle in it
  12. brian eiland
    brian eiland Senior Member
    ...excerpt from a posting of mine under, "New propulsion sytems for ships"..
    One big solution to our energy equation has to be 'storing energy'. We just don't have a lot of good storage capabilities, particularly as related to electrical energy. Many times we are forced to use as we generate it. Think of the possiblities if we could really efficiently store electrical energy. Our sun is a fantastic source of energy as it bombards us with it every day. But our collectors (solar cells) just don't have the capacity to give us the energy density we need to power up a lot of our energy consuming items. And we need better storage methods than our current crop of batteries.
    I have always had an interest in 'super flyweels' as a storage method ever since I learned of their original development by Johns Hopkins Labs years ago doing my college days. Hopkins wanted to put BIG flywheels (at the time low-tech weighted wheels) in underground chambers at power plants and have the excess energy available at night from these plants spin up the wheels so they could be called upon the next day during peak periods rather than turning on a 'peaking turbine'.
    And I began to follow their re-development in the late 90's as several parties sought to re-invent them for auto use. I was real excided when Chrysler sought to enter La Mans with a flywheel powered car.
    I still have a lot of old material stored away on this subject (before my computer days). But I believe if you simply 'google' "super flyweels" you will get a lot of info, for instance:
    http://www3.ntu.edu.sg/home5/PG01898441/flywheel.htm
    ...more here
    http://www.boatdesign.net/forums/propulsion/new-propulsion-sytems-ships-9630-11.html#post85848 posting#163
  13. Frosty
    Frosty Previous Member
    A spring is a good store of energy and 100%efficient. Push with 50lbs and you got 50lbs, it don't go away and will stay for years.
    The uneveness of the road could be used to store spring energy with a ratchet type of gadget. Like absorbing wave energy. But by road energy the faster you go the more energy you make.
    I hav'nt invented it yet infact I just thought of it then.
  14. Boston
    ok how about back on track with a good question from Masali that frankly I should have answered better
    steam consumption on the engine being considered is 1000 to 2000 lbs an hour
    I will have a steam recovery system to recycle at least some of he heat and steam using a simple condenser coil and relief valve in a closed loop system
    although the system comes with provisions to allow for using sea water I think it best for the durability of the engine to go with a steam recovery system and use distilled water
    so you were right Mas about the water maker
    I need one but not as large as you might thing
    it all depends on the efficiency of the recovery system
    the pellet consumption rate at full tilt or about 14knots as it compares to the power requirement of the original twin diesels is
    so to get the same BTU takes about twice the mass of pellets than diesel although the cost is only half per BTU
    about
    the actual number is
    .089/.024=3.7 per penny mass
    738/435=1.7 per penny btu
    3.7/1.7=2.18 times the mass of diesel for the same btu of pellets
    so for the same range I would need 2.18 times the mass of diesel in pellets
    the original boat held 300 gallons at 7.15 lbs each thats 2,145lbs
    and had a range of about 270 miles
    so it would take about 2.18x2,145lbs=
    4,676lbs of pellets to do the same
    If I wanted to hop the pond in one fell swoop I would need to go from
    1866/270=6.9
    6.9x4,676=32,316lbs or 16.17 short tons and Ild want "tons" extra to attempt the trip with
    call it 20 short tons of fuel pellets
    should take about 187 hours depends on currents and wind or about 8 days to make the crossing
    an a lot of stoking
    could be done but Ild be riding about 16" low in the water when I started out if I didnt unballast the ship any
    basically means water ballast is going to be my best bet
    hmmmmmm
    187 hours and 32,316 lbs = 173 lbs an hour at 10 knots
    so I need a 1500 lb capacity hopper to get a decent nights sleep
  15. Frosty
    Cripes this thread is getting as bad as that global warming thing.
    Ooooh I do miss the Drivel thread, it did have its purpose you know.
    1. boarding bob
