The Wind Powered Sail-less Boat
Discussion in 'Boat Design' started by DuncanRox, Oct 20, 2008.
  1. tspeer
    tspeer Senior Member
    I should be ashamed of myself for lobbing such a piece of red meat as DDWFTTW into a pool of alligators like this forum just to watch the action! ;-)
    The attached file is rather off topic, but it is an elegant analysis of another form of wind-powered travel that can go down-wind 40% faster than the wind. Enjoy.
  2. Windmaster
    Likes: 25, Points: 28, Legacy Rep: 56
    Windmaster Senior Member
    Albatrosses can go downwind faster than the wind!
    An Albatross, or a glider, or any aircraft can certainly travel downwind faster than the wind. It needs to move through the airmass in order to stay aloft.
    It's speed over the ground directly downwind = its flying speed + the windspeed.
    I don't think anyone could dispute that.
    But you never know on here!....:?:
  3. Tcubed
    Likes: 18, Points: 0, Legacy Rep: 318
    Tcubed Boat Designer
    Thank you Speer for that beautiful attachment.
    I had long known of the capacity for energy extraction across a sheared flow like that but had never come across an in depth analysis of it.
    I had also observed the phenomenon being used by seabirds- not only albatrosses use the technique, although they must undoubtedly be the masters of it.
    The technique is actually even more powerful than as described in the analysis due to ground effect. This allows the bird to drastically increase its L/D during a portion of the upwind part of the cycle. This applies in flat water as well.
    Naturally, when there is wind there is also waves and (this is alluded to in the presentation) this allows the bird to time its cycles with the upwind portion of the waves and further enjoy the lift off of them.
    It is interesting to note that the upwind portion of the wind is not necessarily the backs of the waves. In the waning part of a weather system the wind decreases to a value inferior of that of the celerity of the wave trains created previously by the stronger winds.
    There is yet another phenomena which i saw used in a calm (when there is no wind shear) and that is simply flying down the faces of old swells. By adjusting flight speed to coincide with the celerity of the swell the bird remains in the lift area and "surfs" down it, at least until that swell reaches the end of its group and decays.
    The upshot of all this is that there are many ways to extract energy from a velocity gradient and the speed of the object is limited by its own efficiency, unbounded by the actual velocities, or velocity differences within the energy giving flow.
  4. markdrela
    Likes: 30, Points: 28, Legacy Rep: 324
    markdrela Senior Member
    I think what you're describing is "slope lift", which is not what the albatross uses. It uses the horizontal wind shear -- the vertical velocities near the waves are relatively insignificant.
    The most spectacular example of Dynamic Soaring today is done by RC sailplanes. This is done on the downwind side of a hill, by circling through the shear layer which comes off the hill crest, much like an albatross circles in the surface boundary layer shear. The current DS speed record is 371 mph, in roughly a 40 mph wind. Here's one video as an example:
    http://www.youtube.com/watch?v=Vi0hrjqU15I
  5. Tcubed
    That's right, which is why in the presentation Barnes specifies waveless seas, so as to analyze dynamic soaring independently from slope lift effects.
    In reality the bird soars dynamically, but also takes advantage of the slope lift where and when possible. So the bird really has a range of options from which to maximize it's energy efficiency.
  6. Boston
    Boston Previous Member
  7. Boston
    it would be so easy to get sucked into this again
    thank god I dont know Jack about birds
    as for why can the rc go so fast
    think circular flight pattern on an oblique plane in a steady updraft
    normally angular momentum is defined as
    J=mvr
    ( dam I hope I remembered that right )
    but this case is not simple angular momentum as there are two drivers in the system
    gravity and wind
    not sure I can but maybe I can dream up a defining equation for the amazing speed that rc is gaining in these conditions
    I think the energy in a flywheel is defined as on half its moment of inertia times its angular velocity squared ( squared part is the kicker )
    basically
    E=1/2AvI2
    ok doesnt write very well on this computer
    now two things about that number
    angular velocity is measured about a radian with a fixed center of rotation
    and we dont have a fixed center of rotation
    so there are multiple centripetal forces at work
    both I think would result in the squaring of the velocities they impart
    ( not sure thats a fair way to handle it but it feels right )
    ( feel free to help if you know the proper calculation )
    dam I havnt tried to work this king of thing out in a while
    ok so
    there is a oblong instead of circular flight pattern but Im going to work it out like it was a flywheel with an imaginary increase in the length of some of the radians with out an increase in time for those radians because they center of rotation is altering relative to ground not relative to wind
    ( if that makes any sence to anyone else feel free to applaud )
    because the wind is pushing this thing at whatever wind speed is faster with each loop
    so Im going to try to add for the wind boost at perpendicular to wind
    and emagine its neutral on the dead down wind and up wind runs
    into and upwind there is no relative gain but the velocity caried out of each turn should carry along just fine
    also there is a gravity gain with each loop 9.91N I think for the drop in altitude considering mass and that the uphill climb can be attributed to wind direction and lift
    so thats 9.91N
    measured in
    drum roll people
    NEWTONS
    ok gotta go flip laundry
    brb
  8. Boston
    ok
    dam I got sucked in again
    complex orbital mechanics was one of my favorites
    the short answer is that oblong pattern is helping out a lot
    the oblique nature of the pattern is adding some
    the wind itself is the main driver and is driving him faster with each circuit competed
    the gravitational force is adding some
    so
    hella fast
    hows that for a technical explanation
    guess laundry brought me back to reality eh
    love B
    dam I just remembered
    its called hyperbolic excess velocity and there is some formula that some one is about to rub my nose in that covers the concept
    Hella fast
  9. Tcubed
    Ummm.... Actually that sailplane is flying in an area of sink, not updraft.
  10. Boston
    did any one notice the smog in the background of that flicker
    wow
  11. markdrela
    In RC Dynamic Soaring, updrafts and gravity are both are irrelevant. There is no updraft on the downwind side of the hill where DS is done, and the airloads are vastly greater than the gravity forces. The plane is driven entirely by the horizontal velocity difference across the shear layer.
    One can make a crude force/power analogy of DS and conventional sailing:
    * The wind shear layer is like the air/water interface, but smeared vertically somewhat.
    * When the glider is above the shear layer its wings act like sails.
    * When the glider is below the shear layer its wings act like the keel.
    * Both the DS glider and the sailboat extract power from the velocity difference across the shear layer or air/water interface.
    One difference is that the "sail" and "keel" driving forces on the DS glider are intermittent, while on a sailboat they are steady.
    One could imagine a flying fish doing "dynamic soaring" in a strong wind storm. The fish leaps into the air against the wind, spreads its fins/wings and does a 180 deg turn, dives back into the water with fins mostly folded, does a 180 deg turn underwater, leaps back into the air, etc. If its drag is low enough, the fish could do this by inertia alone, without any muscle power.
  12. Joakim
    Likes: 53, Points: 28, Legacy Rep: 422
    Joakim Senior Member
    Is gravity really irrelevant? As a first thought I would think gravity is very necessary, since it used to gain speed. Is it not important that there is gravity and thus you are able to gain potential energy while going against the wind?
    I think there always has to be a connection between the two different velocities/fluids. In DDFTTW it is the transmission between the propeller and turbine and in soaring it is the gravity. I may be wrong about soaring, since I haven't yet understood it well enough.
    Joakim
  13. markdrela
    The high and low points of the orbit are about 50m apart vertically. That translates to a change of 500 J/kg in potential energy. When the glider is going at 160 m/s (360 mph), its kinetic energy is 12800 J/kg. So the potential energy changes are just a few percent of the kinetic energy, i.e. negligible. Another way to look at it: When a 160 m/s glider drops down the 50 meters without drag, its new speed from the extra energy is only 163 m/s --- not a significant change.
    The only requirement is that there is a zero net force vector, in order to produce a steady state operation. In DS, the net force vector is zero when averaged over the orbit, since the orbit center stays in place, and doesn't accelerate away.
  14. Boston
    I gotto wonder about that
    if you look at any attempted circular pattern in a cross wind up draft
    or call it what you may you would get some slipping relative to ground
    thus my thought there would be an excess hyperbolic velocity
    also since the velocities of the radian is squared it actually would add significantly
    I think
    I didnt crunch any numbers
    but
    seems like it aught to be
    B
    could be why there plane broke
  15. Tcubed
    That's a nice analogy you've offered and should help people imagine what is going on. The plane is almost "bouncing" between being a keel and being a sail.
    However, to be slightly pedantic, there will always be sink to leeward of a mount like that. The amount of sink will depend naturally on the specific topography,flow separation etc.. The sink is adverse to soaring so the pilot must be fairly proficient at getting into DS mode or he'll lose the model down the slope.
    But yes, once at speed the sink becomes a relatively unimportant factor.
