The Wind Powered Sail-less Boat
Discussion in 'Boat Design' started by DuncanRox, Oct 20, 2008.
  1. Guest625101138
    TUO
    I essentially agree with what you say. I have concluded that most of the time the upwind set up would be used. For any practical purposes the difference between the upwind boat and the DDWFTTW boat would exclude their combination in a single system. It is somewhat like trying to make a spinnaker a good upwind sail or making a flat cut jib a good directly downwind sail.
    As for getting the thing moving downwind I would expect the following to occur.
    Think about the propeller blades and turbine blades connected on a common shaft with the propeller having a pitch of 1m and the turbine having a pitch of 3m. The propeller blades will present almost flat surface to the line of the hull. The turbine blades will have a much flatter angle to the line of the hull.
    With everything at rest the wind past the blades will be trying to turn the propeller backwards but they are in a stall condition with AoA maybe 80 degrees. They might give a slight nudge backwards but this will be strongly resisted by the turbine blades churning in the water - effectively rotating paddles given their angle to the line of the hull.
    The wind is exerting force on the propeller and the boat superstructure so it starts to move forward. Remember that a boat does not have static friction so the slightest force starts it moving. The windspeed past the propeller reduces so its tendency to turn backwards is reduced. Water is now moving past the turbine blades. The AoA of these blades is only around 40 degrees at rest so they will be generating maximum lift and high torque. This torque will overcome the counter torque from the propeller and begin to turn it forward.
    So we now have both the turbine and the propeller spinning in the forward direction. The local slip steam at the propeller blades is going backwards relative to the boat although the far field apparent wind is still moving forward faster than the boat. So the propeller is now creating its own localised apparent wind due to its forward rotation.
    The boat speed will continue to build until the power produced by the turbine balances the power absorbed by the propeller plus the drag on the hull and air drag on the boat when it exceeds the wind speed.
    If you wanted to demonstrate a boat it is easy enough to do an unmanned model. I would use a long slender hull about 20ft long and maybe 6" beam with two small stabiliser. Make a propeller using carbon fibre 4m in diameter and pitch around 1m. Mount this near the bow. Make a steel turbine 0.6m in diameter with a pitch of 3m. Mount this at the stern. Connect turbine to propeller with a 1/4" spring steel shaft. The shaft would need three intermediate supports to prevent vibration.
    You need a large prop to get any reasonable efficiency because the wind speed is so low. You need a long slender hull so the wave drag does not rise too quickly. The single curved shaft supported on bearings will have very low losses.
    You then need to find a place where the wind is blowing steadily around 10 to 15kph. Set the boat at the start of a course that has small waves and let it go. You could video the exercise showing a ribbon being blown backwards and post here but the skeptics will remain skeptics and continue to look for the trick because they simply lack open minds and the ability to reason.
    I would applaud the effort for curiosity sake. Windmaster might even claim you to be world famous.
    Actually I am impressed that there are so many more people now building the DDWFTTW wheel vehicles to satisfy their curiosity. I expect it will only be a matter of time before someone tries a boat.
    Rick W.
  2. Guest625101138
    Tcubed
    I have full VPP models for turbine/propeller boats that are modelled on actual blade profiles and foil polar data over the full range of Re# used in the analysis. I expect if you do the same you will conclude that you cannot find a workable solution that covers all bases irrespective of what you do with variable pitch and variable transmission .
    In my view the best solution for a practical boat is using electric motors/generators in combination with batteries for storage and solar cells for a little extra energy input in calm weather. The only benefit in making the air turbine able to operate as a propeller is as a back-up to the water prop. Similarly it is unlikely that the water prop would ever be used as a turbine.
    The ability for DDWFTTW is of such limited value that it is not worth while contemplating other than for curiosity value.
    Rick W
  3. Tcubed
    Likes: 18, Points: 0, Legacy Rep: 318
    Tcubed Boat Designer
    I'm aware that you are a proponent of this system to be used in conjunction with energy storage systems and i agree that on the whole that is doubtless the most pragmatic setup, despite the energy losses.
    I'm also aware that optimization across all scenarios is impossible without organically morphing foils, which are as yet beyond the wonders of high tech engineering.
    However i admire the simplicity of the directly mechanical setup and am analyzing the mechanics of it in a simplistic way so far. I have solved the first part and would appreciate someone going over it to check i have not made a mistake and if the equations can be reduced further as they are quite complex. I don't feel like attemting to type the workings in here as i'll be at it for hours. I guess i'll fotograph the paper and post that (tommorow) .
    I believe that gaining full understanding of this phenomenon is beneficial to better understanding some of the subtleties of regular sailing craft.
    The data you have i would naturally be very interested to see.
  4. Boston
    Boston Previous Member
    please people, I know I am treating this a little harshly, but when I see this kind of blatant failure to comprehend the most basic tenants of physics
    its just hard to not snicker a little
    these numbers are laughable
    folks must be talking fig newtons
    cause the newtons we use in physics are dependent on mass and velocity
    not just velocity
    if you want math, try this ( its about as basic as it gets )
    N=kgV/s2
    this is some really basic stuff but apparently it needs to be explained
    Ill give you a hint although all the hints Ive dropped so far have been ignored
    N = newtons
    energy
    as measured in newtons is directly proportional to velocity and mass
    not just velocity
    if you need to ask questions
    dont
    this is pathetically obvious
    I attempted to add mass to the equation early on
    knowing that the system wouldn't survive the proof if I did
    its max speed potential can only be its kinetic energy minus friction once distributed to all moving components of the system
    something else I pointed out earlier
    but it got ignored
    anyone wonder why
    why would the proponents of this system refuse to address an obvious proof of the system
    keeping it simple the max energy of this system
    if the plate and the cart both weigh the same ( say 2kg each )
    and if the cart starts out at 0m/s and the plate at 2m/s
    is 1kgm/s
    doesn't mater what the gearing is
    we will consider torque in a moment
    I pointed the mass component out earlier
    but because it screws up the results
    and because there were obviously preconceived results
    and because the lesson in perpetual motion insisted on ignoring mass entirely
    the folks on the band wagon insisted on ignoring my comments
    which is one of many reasons your model
    your understanding of the most basic physics
    and your conclusions
    are laughable
    in the real world
    we have mass
    I want a few of you folks to drop a large rock on your big toe a few times
    till you learn about mass
    also
    this model
    ignores delta T and
    if you consider delta T then you find a system in perpetual acceleration
    doesnt work without perpetual increasing the available energy
    (is the word perpetual anathema around here, cause its what this thing represents)
    its a simple fact that in any system
    the faster you go
    the more friction
    the less energy you have available as positive velocity
    so again
    the system only provides diminishing returns in the real world
    if it constantly wants to accelerate from the fixed energy source of the plate
    ( ok so now Im about to be told the wind takes the place of the plate and the top roller is the wind turbine )
    ( makes no difference, run that directly down wind and it'll still hit the same relative wind barrier Ive been pointing out from the go )
    ( run it across the wind like the ice racers do and all the moving crap makes you slower than they any day )
    if you were to actually graph the results of the energy requirement of the system over time you would find they are required to increase exponential
    why do you think I wouldnt play the game in the first place when I gave you the proof considering for mass
    next problem
    torque
    your torque considerations are completely fictional since you ignored mass considerations
    and
    the energy of the rotational velocity of the wheels is directly subtracted from the forward motion of the vehicle
    and no
    Im not going to explain that one
    its way to advanced for a class that's just learning that N is in some way related to mass and not just velocity
    and not something just wrapped around a fig
    ( this model you suggest doesn't work )
    ( for the reasons previously specified )
    ( your welcome to use a fan all you want )
    at this point I dont care how you can do it
    as long as the vehicle is going directly down wind
    you win the beer
    Im actually hoping someone can come up with something
    but so far
  5. Boston
    what I notice most when I watch this is how slow it is
    ( not very efficient what with all the friction in the system from all the gizmo's )
    and that it looks to be decelerating when facing directly into the wind
    so it seems it would end up going backwards on an extended upwind heading
    Ild love to see some time trials evidence if anyone has it
    but it sure doesnt look like its about to beet any speed records
  6. Guest625101138
    Boston
    Can you please explain what you mean by this equation. I accept the N means Newtons - a force.
    what is the k, g, V and S???
    Rick W
  7. Guest625101138
    I have no idea why you would offer this video with regard to the current discussion. It shows an air turbine that is driving a water propeller. The DDWFTTW boat we are discussing has a water turbine driving an air propeller. Very significant difference in operation.
    Rick W
  8. 3dyachts
    Likes: 1, Points: 0, Legacy Rep: 37
    3dyachts Senior Yacht Designer
    Hi all,
    I just had the patience to go all the way this looong thread (reading diagonally at times!). And I was feeling a bit depressed, so l was looking for something a little mind blogging!
    I am ASTOUNDED!
    This started with an interseting question: how to loose a war that has already been fought sort of thing. Effectively, nothing - by far - beats the speed obtainable by simple foils that a "sail" is, sitting on another foil that fights against leeway (and eventually provides lift), if no other power source than present wind is used,.
    Accumulation is then a good answer to the question that was primarily asked, since it was not excluding "internal" power source.
    But then this discussion about the capabilities of rotating foils (call them props, turbines, or else) or other means of using directly or undirectly wind energy by anything that could not be called a sail somehow diverted to this icredible discussion about Directly Down Wind Faster Than The Wind.
    May I first say that any discussion that pretends to resolve a problem should be - basically - about the same problem for everyone? If one says Directly Downwind, that is not even at a fraction of an angle: that is directly Downwind. Period.
    We all know that the ice sledges can go much faster than the wind. NOT Directly Downwind! We all know that diverse experiments have been conducted that show possible to go strictly directly upwind: the result is a desolation, and tacking is much faster altogether, but it works.
    But then, an impressive number of numbers have been written down to demonstrate that what has NEVER worked does actually work! Show one! Do not say "it works, I demonstrate it, but that...hmmm...wait...we think it works..we are sure it does...but...hmmm...well: so long must admit it DOES not!"
    Sorry guys: if, with the basic scientific attitude of following strictly the question as it is written down: DDFTTW: it does not work. Tacking downwind: it works. No matter how you will angle your "wind catching contraption": if the vehicle moves strictly down wind, it will never go faster than the wind. None can be shown. These little vehicles nicely rolling along the road have to be at an angle to the wind.
    Write figures, go round in circles, even do these (sorry: ridiculous!) little sliding ceiling comparison (got to have totally misunderstood the problem to put that here!!!) : NOTHING has been demonstrated!
    Care joining the team for a beer?
  9. kerosene
    kerosene Senior Member
    2 things.
    1.
    If taking downwind makes it possible to go faster down wind can I make a machine that is a broad frame in which a device takes back and forth (down wind) and pushes that cage directly downwind?
    If it is acknowledged that there is no weird science or perpetual motion in traveling faster than the wind when tacking it is only reasonable to extrapolate that it is possible to break those components and go straight down wind without braking any laws of physics. Obviously normal wing can't do that as its loses the flow on its surface.
    2. If you suggest that the small carts are working because they are actually traveling of the wind then how do you explain the treadmill experiment. After all the starting phase of a treadmill experiment is as if vehicle is rolling (directly) downwind exactly at the speed of the wind (no apparent wind).
    Call diagrams ridiculous at least Rick is taking time trying to explain his point.
    And about the practicality of all this. Fully agree traditional wing beats these contraptions clearly - its more of a mental exercise on a dilemma that is counter intuitive and thus gets slammed by people like you.
  10. masalai
    masalai masalai
    2c - besides, I am enjoying the discussion, learning something and having a beer... Keep the discussion going it is interesting....
  11. Boston
    MR 3dyachts
    team beer is ready for some new members anytime
    also
    I notice the timbre of my threads has gotten a little sarcastic
    for that I apologize
    Im just frustrated that the basics of physics are being so flaunted
    and that the perfectly valid questions I raised earlier in this discussion were so studiously ignored
    Rick if you are working in newtons
    and dont know what a newton is
    how much validity can possibly be found in your equations
    Idont mean that to sound harsh
    but it's true
    I just am not going to explain basic physics
    its late
    I had a crap day
    and Im just about out of beer
    I will however explain theoretical physics
    what theoretical physics does is dream up equations about things that for the most part dont exist but maybe could
    it doesnt necessarily propose a solution for those equations
    but it does insist that the equations balance with proofs to show the validity of those equations
    in doing so it requires that all common denominators be resolved and that a consistent and generally obvious question be answered by the proof
    to also show the validity of that proof
    one that must also be answered by the original equation
    it would be something like the conservation of energy proof I proposed for that model you first posted
    as an example
    in relativity old uncle Albert found a flaw
    everyone said he was nuts
    and he went on to be considered over the hill
    but he dreamed up the field equations to try and resolve the problem
    ( by the way folks thought he was nuts for doubting his own discovery )
    the field equations are the example Im going to use here
    they could not be resolved unless you provide an arbitrary number called the cosmological constant
    the cosmological constant is an imaginary number that makes up for the flaw in relativity and allows the field equations to be resolved
    and yet
    everyone clung to relativity with a death grip
    really pissed off All
    now
    about a million years later
    folks are starting to notice that quantum mechanics and relativity dont jive
    ( ok they new that from the start but they've lately given up on waiting for a reason why they dont jive )
    along comes a guy named Joao
    old Jo dreams op variable light spead theory and resolves the field equations
    way to go Jo
    thing is now every one who staked there rep on relativity
    ( which is still good up to the plank limit by the way )
    hates Jo
    why
    why would they hate a guy with a name like Joao
    and not just admit they were wrong in the first place
    they are scientists
    shouldnt they be interested in truth
    thing is we all put our ego's on the line with some of our beliefs
    and some of those turn out to be wrong
    its a grim admission
    so when there is only one of me
    and ten of you
    it doesnt mean I must be nuts
    it could just mean
    that I know a little more than you are giving me credit for
    might just be time to admit that model is seriously flawed
    when you have insisted on a calculating units or measurement in the model that dont exist in the model
    and Ill still buy you a pint
    it was entertaining
    I dont care who is right or wrong
  12. Boston
    oh #$%@
    I just noticed I put v instead of m
    it should read
    N=kgm/s2
    told you I had a crap day
    way to put my head on the chopping block
    its basically the same thing
    but not
    oops
    B
    just I didnt look it up and then I went back and read the question again
    I realized I had mixed the American equation with the conversion equation
    its E=mv2/2
    and N=kgm/s2
    I think
    been a long time since I used any of this crap
  13. Boston
    hmmmmmm
    its kg moving at m per sec
    I think I still wrote that wrong
    but it represents V no matter
    and you should be able to recognise the error in a heartbeat
    hell I think its what caused one of the mars landers to crash
    oh well
    its dam late
    or at least that would be Nasa's excuse
  14. Guest625101138
    Boston
    I have already deduced that you believe simple maths is crap. People usually do not like what they do not understand.
    Rick W
  15. Guest625101138
    The attached clips are not going to make much difference in the debate but it might help those who grapple with the understanding.
    This is a highly imperfect little vehicle, built in 5 minutes, that does work. The wheel slip and flexible belt drive adds a dimension of reality that might trigger understanding in those prepared to open their minds. The vehicle is inverted to achieve the different operations.
    It does show that you can build a vehicle that will advance directly against the force that it causing its motion. It also shows that the vehicle can advance faster than the media that it pushing it. Both examples work through the wonders of gearing. No witchcraft, no strings and no perpetual motion; just gearing.
    Rick W
