seasailor55
Senior Member
- Joined
- Oct 28, 2010
- Messages
- 148
- Reaction score
- Location
- Lake Charles, LA.
On the C-24, you could have slightly more area, though a slight reduction in the main/fore triangle area will permit a bigger mizzen, which is the key to it's usefulness. The Electra was designed under the CCA influences, so a yawl was a viable option if attempting to get a "favorable rate". On the Electra, I'd use the stock sloop rig, moved forward with a new mizzen as it was under powered. A 35-40 sq. ft. mizzen would easily offer substantial power off wind. The Ensign carries more area then the Electra, so resizing the main would probably be necessary. On the C-24, I'd move the main forward a foot or two, reduce the main to the 135 sq. ft. range and then add 70 sq. ft. to a mizzen.
Sounds reasonable. I love yawls, and find them very elegant. Would you use a bowsprit to move the C24 sloop sail plan forward and reduce the main as metioned? Moving the sloop mast forward would require less surgery than retrofitting a schooner rig, since the deck and cabin profile could remain essentially the same. I'll try a sketch to see what it might look like. Thanks for the feedback!
