Test borg warner transmissions
Discussion in 'Propulsion' started by boat3630, Dec 31, 2020.
  1. boat3630
    boat3630 New Member
    What is best way to test a transmission while it is out of boat ?
    The best way is to input power and connect the output shaft to a dyno. What kind of equipment do you have?
  3. kapnD
    Likes: 493, Points: 83, Legacy Rep: 40
    kapnD Senior Member
    Well, it’s not high tech, but lacking a dyno I have tested marine transmissions on the bench many times.
    A stout 1/2” drill motor that will spin 5-600 rpms under load is the power.
    It’s linked to the transmissions input shaft by a short, stout rubber hose clamped over the chuck.
    Make sure there’s oil in the trans, and spin it up. You can attach a pressure gauge, and operate the shift lever to determine basically if the item works.
  4. boat3630
    boat3630 New Member
    Great , what pressure should I have to make sure it is right? I have some pressure gauges. I can build something with a hose.
  5. gonzo
    The pressure should be about 300 psi. I don't know that a drill will have enough power. Also, to test it there should be a load on the input shaft to check the clutches for slippage. You asked for the best way, a drill is not even close to mediocre.
  6. missinginaction
    Likes: 258, Points: 83, Legacy Rep: 512
    missinginaction Senior Member
    Gonzo, I have a question for you. Remember how I've been changing over my v-drive? Well, after I took the drive out I decided to replace the hydraulic lines on the Velvet Drive. I never noticed any slipping or problems with the transmission but one thing struck me. I pulled the little screen out of the transmission that sits behind the lower right side hydraulic line. There was absolutely no debris in it. I never looked at this fitting in the years I owned this boat. Wouldn't this screen be a good indicator of overall transmission health?
  7. boat3630
    boat3630 New Member
    If you were me how would have it tested?
  8. kapnD
    kapnD Senior Member
    So the guy needs to set up a dynamometer in his garage to see if a transmission works?
    Your old 9 volt battery drill will be useless here, but a good old 1/2” arm breaker will spin it up nicely.
    Give the oil a sniff test, if it smells burnt, suspect worn clutches.
    Also examine oil from the sump in bright sunlight, looking for metallic particles.
    If you have any doubts, rebuild it, old BW s are easy and cheap to rebuild.
    Suggest downloading a manual.
  9. boat3630
    boat3630 New Member
    I am rebuilding it now I was just wanting to have a way to test it. Should I just take it to a transmission shop? Will I be able to test it with a 200 lb gauge?
  10. gonzo
    He asked for the best method, which means using the proper equipment.
