Survival Draft
Discussion in 'Stability' started by Leopard, Nov 24, 2021.
  1. Leopard
    Likes: 4, Points: 8
    Leopard Junior Member
    Could you please tell me how to calculate the survival draft for a floating platform?
    I will also appreciate if you have a sample stability booklet for an offshore platform.
  2. jehardiman
    Likes: 1,515, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    How many legs; 5,7,11, or 13?
  3. Leopard
    Likes: 4, Points: 8
    Hi, The vessel looks similar to this. It has 6 vertical columns and two pontoons.
  4. jehardiman
    Ok, now what do you mean by "survival draft"? Draft at Instability? Loading Conditions? Stable Draft after Damage? Draft needed to have a 99.xxx percent chance of surviving a Beaufort/NATO SS y storm in zzzz feet of water? There are lots of ways to sort this and thousands of different answers depending on the case used.
  5. gonzo
    Likes: 2,415, Points: 123, Legacy Rep: 2031
    Leopard. You are posting questions that appear to be homework. For a Naval Architect working at a shipyard, like you claim to be, the calculations should obvious. As was told to you before, regulating bodies, laws, class regulation, etc. will give you the answer. However, you need to ask the right questions. For example, a sample booklet from China is likely to be useless for the EU. Also, instead of posting an image that is a free download, post an image of the platform you are referring to; that is assuming such platform actually exists.
    DogCavalry likes this.
  6. Leopard
    Likes: 4, Points: 8
    Draft needed to have a 99.xxx percent chance of surviving a Beaufort/NATO SS y storm in zzzz feet of water? Yes I am looking for this. Could you please tell me where to look about this?
  7. Leopard
    Likes: 4, Points: 8
    Do you have any booklet written in English, please?
  8. jehardiman
    I would suggest the Handbook of Offshore Engineering (2-volume set) by Subrata Chakrabarti.
    Leopard likes this.
  9. Leopard
    Likes: 4, Points: 8
    Thanks a lot
