Crashcart2
New Member
- Joined
- Feb 23, 2024
- Messages
- Reaction score
- Location
- Virginia
I'm currently working on the design of an 18' skiff with a design waterline of 8", full load displacement of ~ 1800 lbs. This boat is meant to be powered by a 115hp outboard on a standard 20" transom height. Max speed around 40 knots most likely. A lightship weight in the ballpark of 750lbs (hull only) is expected.
Looking for advice on how to design the boat's stringers/bulkheads and transom structures without overbuilding. This boat would be built as a one-off using composite core materials and glass. The transom would most likely be of a coosa board core.
I've read Gerr's book, any other recommendations?
Does anyone know how to factor in the additional loads of a jack plate on a transom as well? Thanks !
