Strange Propeller
Discussion in 'Props' started by sottorf, Sep 17, 2012.
  1. sottorf
    Likes: 20, Points: 0, Legacy Rep: 202
    sottorf member
    Does anybody know anything about the prop shown below?
    Any technical papers available on its hydrodynamics?
    My thoughts are it could be very efficient in certain specialized applications but this is pure speculation right now.
  2. hoytedow
    It is very unusual. Is it for stirring ingredients?
  3. WestVanHan
    Yes Hoyt that is my first thought- a food blender.
  4. gonzo
    Likes: 2,293, Points: 123, Legacy Rep: 2031
    Looks like a standard paint mixer.
  5. Petros
    Petros Senior Member
    A design like that is not efficient at all, at least not for generating thrust. I doubt it is a propeller, but rather as speculated a mixing blade of some sort. Either that, or some inventor's idea that knows nothing about efficient prop design.
    It has a square leading and trailing edges, low aspect ratio blade, there would be pressure loss over the surface of the blade where it would bleed through the large "hole" or hoop on each blade. I can not see how it can generate efficient thrust at any speed.
    Where did you find it.
  6. whitepointer23
    it is definately an industrial mixer paddle, did you think it was off a boat.
  7. CDK
    CDK retired engineer
    This is an industrial mixer paddle for liquids, probably corrosive ones. A closed design would cause violent movement at the surface of the mixing tank; the large holes between hub and blades allow the liquid to circulate and confine the mixing process.
    I briefly worked in a company where they made such products from stainless steel, brass and pure gold, depending on the liquids involved.
  8. sottorf
    sottorf member
    There has apparently been some literature publisehd about it for marine use in Russian literature and am trying to find out more...
    Seems like nobody in West has heard about it.
  9. whitepointer23
    mixing marine paint would be about it .
  10. MikeJohns
    MikeJohns Senior Member
    Some submarines early last century used similar props for low noise and reduced wake but not for efficiency.
  11. Frosty
    Frosty Previous Member
    Its not a prop --come on,-- look at the thickness of the blade, it goes against all prop basics.
    It looks to me like a prize for something.
    Maybe the Annual Bull ******** conference
  12. sottorf
    sottorf member
    Really objective answer Frosty - thanks for that "useful" contribution!
    The real answer is it is a water turbine development.... See picture below.
  13. hoytedow
    Why not stay with a simple Archimedes screw?
  14. whitepointer23
    still looks like a mixer to me.
  15. hoytedow
    Me too.
