SS316 Bolt heads missing in Tinned Ground plate
Discussion in 'Boatbuilding' started by alby joy, Sep 11, 2020.
Reason for this
Poll closed Sep 18, 2020.
  1. Galvanic corrossion
    0 vote(s)
    0.0%
  2. Som other reason
    100.0%
  1. alby joy
    Likes: 0, Points: 6
    alby joy Junior Member
    Hi,
    Recently when I drydocked my FRP Vessel with Tinned ground plate attached to its hull - Catamaran. The plate attachment bolts used was SS316. Now I cant see any Bolt heads for the Bolts (SS316). Is it have an issue related to the galvanic corrossion.
  2. sdowney717
    Likes: 118, Points: 73, Legacy Rep: 274
    sdowney717 Senior Member
    Regardless, can you replace with bronze bolts, washers and nuts? Obviously the SS is having issues. All my underwater bronze bolts underwater for 50 years have been excellently preserved.
    jehardiman likes this.
  3. jehardiman
    Likes: 1,485, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    If the heads are gone, but the body is intact, it is crevice corrosion which 316 is susceptible to. As sdowney717 says, switch to bronze or monel.
  1. nbehlman
