Sprayguns.....
Discussion in 'Fiberglass and Composite Boat Building' started by Roly, Nov 5, 2011.
  1. Roly
    Likes: 23, Points: 18, Legacy Rep: 222
    Roly Senior Member
    Can anybody recommend a cheap gravity spraygun for polyurethane 2pac for topside painting.?
    I can remove the gravity feed & place my pressure pot line into the top if need be. I have done this with my Sharp with a 2.3 tip for hi build epoxy & it worked well. I have some crappy chinese guns 2.0 & 1.7 but they don't give me any confidence, altho I've been told they do make some good look-a-likes of name brands. I aint making a career outa this hence the cheap! Besides its "hand to mouth" getting this boat finished.
    Ta.
  2. waikikin
    waikikin Senior Member
    On this side of the Tasman we get "Star" brand guns, generally copies of higher cost guns like Iwata etc. Here is some http://www.transquip.com.au/categor...-&-STAR-AIRTOOLS/STAR-GRAVITY-FEED-SPRAY-GUNS , your local panel shop/spray painters supplies should be able to help. I've had excellent results through to average with these guns but the variance would be up to this operator ;) Spend some time on set up & practice shots & on small items discipline yourself to a break for a cuppa tea between passes.Jeff.
  3. gonzo
    You can use one of those cheap gun copies and change the nozzle with the original. It will save you a lot of money and give you good quality.
  4. Frosty
    Frosty Previous Member
    Theres nothing wrong with cheap guns if they are clean. the bleed holes 4 on the nozle needs to be pristine.
  5. tunnels
    tunnels Previous Member
    Make a pressure pot and use one of those crappy chinese guns !! IT WILL WORK !! :p
  6. Frosty
    I dont have any trouble with them. Can I suggest the proverb a poor workman blames his tools.
    You can even adjust air line pressure in the gun and the fan --what more do you want.
    If your painting metalic you need to know what your doing but with todays method of laquer its still easy.
  7. Roly
    Roly Senior Member
    Cheers guys.
    I'll give the yet untried 2.0mm a trial on a test panel. It doesn't have line pressure adjust at the gun but I can easily rectify that. I've done no PU 2pac spraying & just assummed you needed Graco or De Vilbiss stamped on the side to get decent adjustment/ finish.
    I guess I tend to tar all chinese products with the same brush. If one thing falls apart
    they all are going to. Cheap=crap, not necessarily so.
    For the hibuild epoxy I used a pot pressure of 20psi & tip pressure of 60psi. Would it be similar for the PU? Guess I'll just have to trial a it to get good atomisation for the viscosity of the PU. I'll go for a sunny day with low humidity & manufacturer spec for
    thinners.
  8. Frosty
    They just need cleaning like they all do.
