fallguy
Boat Builder
- Dec 7, 2016
- 9,012
- 2,115
- usa
The down angle will be 13.4 degrees below horizontal, then the radius will be on the outer edge. I was hoping to prefinish it all; so if it fails; it would fail on the boat, so want to give it a a best try. As the video shows it is a Lot of water at times. The front of the boat has quite a bit going on. I won’t put anything on the bow extension because it sometimes dips into the oncoming wave, etc.It can do if not positioned correctly.
Make sure you have a minimum 5 deg downward angle (-ve) from horizontal.
This will encourage the flow to be downward and not to attempt to stay attached and go around the rounded apex.
There is a lot of motion in the x plane, so I worry the boat velocity will push the water back and around the radius…
Maybe I ought to sharpen back the first 10 feet of all of them…this would reducc the fairing to half..
