Modern spade with a foil that has a slight hollow aft section, well built out of a mould.
The symptom is one that I have become aware of, not sure if it’s always been there or not. When the boat is stationary if you move the tiller from side to side it’s almost as if the rudder blade is loose on the shaft. I am not discounting the possibility, but I find it highly unlikely since I built the rudder and I am aware of its construction which is fairly substantial.
There is a definite slack/bite feeling as the tiller is moved but when I tie it off to one side then get under the boat and try and wiggle the blade its totally solid????
The only plausible explanation is that the water is attaching and releasing to the rudder, Am I way of here or is there something else I should be considering? It really is very strange.
