Small trimarans under 20'
Discussion in 'Multihulls' started by Doug Lord, Jun 24, 2012.
  1. Corley
    Likes: 199, Points: 63, Legacy Rep: 826
    Corley epoxy coated
    The Supernova is nicely balanced little trimaran as it is with its moderately sized rig. My criticism of the Supernova wouldn't be the small floats but how heavy the main hull is, It's solid glass and the centerboard is just a flat sheet of metal. It has a pretty cool system for demounting all the components for roof topping on a small to medium vehicle. I've heard they can break at the joins between the beam structure and the hulls which do seem a bit flimsy.
    At that point small floats were favoured over large it makes for a less powered up and less stiff platform. As a positive you can also right the boat easily without needing help or having to flood the float like the Weta.
  2. Doug Lord
    Doug Lord Flight Ready
    Supernova
    Thanks, Corley-thats good info.
  3. Doug Lord
    Sea Rail 19
    Here is the new Sea Rail 19 website with more info on the boat. Updates the previous posts 140 and 141 in this thread: http://www.searail19.com/
  4. Doug Lord
    Any more small tri design ideas?
  5. rcnesneg
    Likes: 6, Points: 0, Legacy Rep: 58
    rcnesneg Senior Member
    Just throwing a random idea out there I had never considered before... Biplane rig, each mast is stepped halfway between the vaka and an ama. Rigged just like two catamarans sharing a hull.
  6. cavalier mk2
    Likes: 144, Points: 63, Legacy Rep: 214
    cavalier mk2 Senior Member
    You need to go further and make a triplane.
  7. Doug Lord
  8. Doug Lord
    Robinson 5000 by Dibley
    From the thread linked above-soon to be in the water!
  9. P Flados
    Likes: 33, Points: 28, Legacy Rep: 390
    P Flados Senior Member
  10. Doug Lord
    Paul, I appreciate your concern but this thread is and has been about under 20' trimarans. And the link that I posted is the title Corley gave to that thread, not my idea. I don't really think it is cross posting when the subject matter is the subject of this thread.
    PS-fixed the title of post 458.......
  11. Corley
    Corley epoxy coated
  12. Doug Lord
  13. Doug Lord
  14. Doug Lord
    ONYX 16 Trimaran
    Here are a couple of stills:
    click-
  15. rcnesneg
    Nice find Doug! I like her! Looks like a good solid lightweight boat!
