Small Part Stuck in Mold
Discussion in 'Fiberglass and Composite Boat Building' started by wcnfl, Jan 11, 2010.
  1. tunnels
    tunnels Previous Member
    Number one
    never lay up over oil based paint !!ALWAYS USE A 2 POT URETHANE .
    Number two
    The minimum draw is 1.5 degrees on all surfaces !!!
    number three
    Radius need to be as big as is possible to suit the item you are making ! 4 mm to 10mm radius
    Dont forget when you make a plug make it so you can dismantle it piece by piece from inside the mould not tear the mould apart . :p
    If you have a intricate part the spray a coat of watered down PVA first then was over the top . When you put pva on you can not build up coats just thickness !! And thats the complete opossite to how you should be using PVA . The spray should be so fine that if you can see it on the mould you have to much . I always thin the pva with water about 60% and spray very very very fine . if done properly you dont even need any wax at all !!
    1. brokensheer
    2. youngfella87
    3. ahender
    4. Bigtalljv
    5. Jaco
    6. mrdebian
    7. WalleyeSniper
    8. Tom Mckinney
    9. revintage
    10. teneicm
