Sliding Hatch Coaming Design
Discussion in 'Wooden Boat Building and Restoration' started by motorbike, Jul 15, 2015.
  1. motorbike
    Likes: 10, Points: 18, Legacy Rep: 87
    motorbike Senior Member
    I've got a companionway hatch that needs redesign, the design has two runners with external rebates for the brass strip on the hatch to slide in, the hatch has an aft transverse coaming which limits forward movement and has a hasp on it for locking on the washboards when pulled shut. It has a forward transverse coaming which limits aft movement and when pulled shut butts up against the matching transverse coaming which runs between the two runners on the cabin top.
    That cabintop coaming is removable from inside the boat to allow the hatch to be fully removed by sliding it aft, but it leaks as the design is inherently faulty. Its impossible to seal the joints and have them removable as well, I want to glue that coaming in place but doing so would mean making the either one of the coamings on the hatch removable. Dont want to put screws though the top of the hatch, which seem very amateurish, whats a good way to do this job as I am sure it has been solved many times?
    Likes: 2,261, Points: 123, Legacy Rep: 2031
    Could you post some photos?
