ExileMoon
Junior Member
- Joined
- Oct 23, 2009
- Posts
- 68
- Reaction score
- 21
- Location
- Shanghai
I'm thinking of a 40-foot sailboat. According to the common practice, do ordinary ding sailing. So that the height of the mast will be relatively large, the bottom of the ship had to install the protruding keel to ballast.
I would like to be able to make a shallow draft boat, the mast made of two, so that in the case of the same sail area, the mast height can be lower. This does not require a deep draft of the balloon.
The lower mast does not need to be reinforced with a cable, so the whole structure is relatively simple.
Some people say that this boat is called "old man ship". Meaning that the boat is easier to operate and does not need to be adjusted too much.
I think it should be a good thing.
But this kind of double mast sailboat rarely seen.
What is the reason?
