Silly mistake!
Discussion in 'Fiberglass and Composite Boat Building' started by member 35191, Aug 31, 2010.
  1. member 35191
    member 35191 Previous Member
    Just thought id share a recent balls up with you.
    We had a hole in our transom due to a collision with a submerged car, so we lifted the boat and today grinded it all back made the hole ready to repair, filled with ply wood and resin. Little did I know that the local resin ( im in Nigeria) is not pre accelerated. And we only have two days in the dry dock, so now we begging for more time to lay up before we can continue with the repair. Oh well live and learn!
  2. larry larisky
    larry larisky Previous Member
    this is my philosophy.
    don't explain, don't complain
  3. alan white
    Likes: 122, Points: 0, Legacy Rep: 1404
    alan white Senior Member
    Thanks for explaining your philosophy, Larry.
  4. Herman
    Herman Senior Member
    Best is to take it off, and redo the repair. It might even be the fastest solution.
    And yes, that sucks.
  5. zerogara
    Likes: 5, Points: 0, Legacy Rep: 67
    zerogara build it and sail it
    I think the reason they do this is because in high temp environments resin lasts longer that way, otherwise it tends to turn to molasses.
    Every time you get a new batch of chemicals it is best to use a small quanity for a test. I once had bad catalyst sold to me and it took a while to figure it out till I used some of my old left over catalyst.
  6. anthony goodson
    Likes: 19, Points: 18, Legacy Rep: 256
    anthony goodson Senior Member
    And keep the accelerator ,when it arrives, stored well away from the mekp.
