Hi!
I'm starting up this thread in an attempt to learn about, and discuss self-righting multihull designs and righting aids/systems.
Is there any production multihull which is self-righting?
Is there any production multihull which can be singlehandedly righted after a capsize? (Small beachcats and scale models excluded)
Which are the best aids/systems on the market?
I have a Hobie 14 and have flipped it many times, both to its side (110 degrees), and completely upside down (180 degrees). For me (175cm, 65kg) it is quite exhausting to right it myself, especially in heavy weather, where it can easily get caught by the wind and rotate 270 degrees around centerline, so I have to start over again. And without the trapeze harness on me, or if it had a slightly larger beam, I wouldn't be able to do it. I can imagine the fear after flipping a large catamaran in the middle of the ocean.
