Seawater Strainer
Discussion in 'Boat Design' started by steve123, Jan 29, 2015.
  1. steve123
    Likes: 2, Points: 0, Legacy Rep: 20
    steve123 Junior Member
    Hi,
    Have a large aluminium sea strainer which has to be coated inside because of the S/steel mesh filter, any reason why it cant be an aluminium mesh filter ???
  2. BMcF
    Likes: 113, Points: 63, Legacy Rep: 361
    BMcF Senior Member
    It won't be around very long if made of aluminum and you are operating in salt water.
  3. gonzo
    Likes: 1,488, Points: 123, Legacy Rep: 2031
    I've never seen a sea strainer in aluminum. It is one of the worst possible metals for it.
  4. TANSL
    Likes: 651, Points: 123, Legacy Rep: 300
    What material are the "aluminum sea strainer" you have seen ?. Would it be correct to assume that a "aluminum sea strainer" can only be aluminum?
  5. steve123
    The boat is made of Aluminium-Magnesium Alloy as is the sea strainer but the mesh filter is S/steel so we have to coat the sea strainer, hence the question.
  6. myark
    Likes: 16, Points: 28, Legacy Rep: 57
    myark Senior Member
  7. gonzo
    I often use plastic sea strainers. Never had a problem with them.
  8. steve123
    The guy in China is Noel...they dont do them big enough.
  9. myark
    myark Senior Member
    The guys name is actually Hyde ..... who was also lost wax investment casting large keels made in stainless as well as rudders and shafts for sailing boats
  10. michael pierzga
    michael pierzga Senior Member
    I dont like the idea of an aluminum strainer. Ive never seen one.
    Stainless is what Ive used. Epoxy primed and anti fouled.
    Plastic may be possible.. I have no experience
    Perhaps a plastic pipe with holes drilled.
    A fine screen works best
  11. baeckmo
    Likes: 569, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    There is no problem with an alu strainer body in an alu hull, but the filter element ("basket") in SS must be galvanically separated from the alu body. Depending on the design, this can often be achieved by adding suitable distance pieces.
    Note that rubber contains carbon, which is "lethal" to alu in salt water applications, so the isolators should be nylon or similar.
  12. gonzo
    Your comment about rubber is interesting and good to remember. I have often used neoprene under aluminum tanks. Searching what thickening agents are used, carbon is one of them. From now on, I will check. Thanks
  13. Ae Jae
    Ae Jae Junior Member
    Good point about the rubber, got me thinking (nervously!) but I'm sure our seals were silicon. Our raw water inlets are bronze. I've changed to plastic baskets/liners as the old ones disintegrated. The plastic seems to last longer and would be less damaging to the impeller, if bits did come off.
    A
  14. sdowney717
    Likes: 84, Points: 58, Legacy Rep: 274
    sdowney717 Senior Member
    I made a plastic sea strainer for a 1.25 inch Sendure Y strainer.
    It is a square flat piece punctuated full of squared holes made for crocheting? from Michael's arts and crafts.
    people run - hook yarns onto it, so it is a framework.
    It was a little stiff to roll, but a heat gun helped.
    I then stitched the edge together using copper wire. But you could use fishing line.
    I did that about 5 years ago, and it has worked flawlessly. Where we boat there is not really anything in the water, jelly fish could be sucked in I suppose. I have only ever seen some sea grass caught in it.
  15. viking north
    Likes: 92, Points: 48, Legacy Rep: 1146
    viking north VINLAND
    I'm not sure of the size you require but one of the ships lifeboats I converted was an aluminum hull. I used an all plastic Vetus manufactured sea water strainer or as we call them here raw water strainers. It did however have a neoprene or soft plastic O ring but never ran into any problems with it.
