sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Messages
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
I have discovered that this stuff here.
http://www.permatex.com/products-2/...sor-safe-high-temp-rtv-silicone-gasket-detail
Will not burn off the surface of an exhaust manifold.
I first used this instead of an exhaust gasket between head and manifold on my Palmer IHC 392 engine. The mating surface of the manifold had some rusted defects and the standard gasket could not seal it. Since then I resurfaced the manifold on an engine rebuild. But it worked filling a 1/16 inch gap.
Second was on the Onan 6500 MCCK. The exhaust gasket had failed. I used this instead AND I coated on the lower flange of the exhaust manifold where it always burnt off any paint and it would rust there. Now after couple years, this Permatex orange is intact and NO rust appearing on the exhaust manifold.
Third is recently on the starboard engine, the part that joins water cooled exhaust manifold to water cooled riser rusted through. The part is at least 30 years old, maybe even to 1970 and made of cast iron. This short part has no water cooling and gets very hot. I had a machine shop fabricate a new part from steel. I thought why not coat with permatex orange, and I had no gaskets to use.
So I coated entire part with Permatex orange, smeared on the inside and outside. and used it for a gasket. Result was perfect, ran all day, no leaks.
Came back to slip and checked it. Perfect, no discolor, no burning off, still well attached to the steel. My thinking is it will seal the steel and it wont rust.
I see Permatex has one with slightly higher heat than this one. So if you want to keep rust away on exhaust manifold surfaces, try it.
