no, no, no, no, no, no
Sailing canoes come in shunting types, and tacking types. The flexible ama technology is brilliant for the pacific proa type. It gives the ama a suspension mechanism that allows the ama to pivot in pitch independently of the vaka. This is suitable for shunting with the ama to windward. It is totally unsuited to ama to leeward, which happens half the time on a tacking canoe. You need a fixed attachment, for when the bow of your ama goes into a wave. In this scenario the bow of your ama is pushing up and trying to raise the entire boat so that it does not faceplant right into a huge wave. Imagine a trimaran flying along into a wave, and just forget for a moment that the other outrigger is not there. You want the outrigger in the water to be strong, and to push the bow of the ama up.
The upside is that your ama does not need to be huge, say for example it weighs 30kg, and has a volume of 130L, which is 15kg of ama, and you add an extra 15kg of stores, be that chain, water, food, spare anchor, camping gear etc. On one tack you only have 30kg of weight. On the other tack, ama to leeward (trimaran tack), you only have a maximum upward force of 100kg (130kg - 30kg). You ama cannot push up more than 100kg otherwise if would sink.
Of course apply a factor of safety.
To sum up, the flexible ama technology is not suitable for tacking canoe (only shunting), the maximum loads are proportional to net ama volume, and for a ama of moderate volume, maximum loads are modest
For more information see here
tackingoutrigger.com -- tacking outrigger sailing canoes http://www.tackingoutrigger.com (my website) or the newly formed facebook group on tacking outrigger canoes
Facebook Groups https://www.facebook.com/groups/217818223302263
