Rust inside the fuel tank.
Discussion in 'Gas Engines' started by thudpucker, Jun 12, 2014.
  1. NavalSArtichoke
    Likes: 8, Points: 0, Legacy Rep: 83
    NavalSArtichoke Senior Member
    It's not clear what this means. Rust is pretty stable once it forms. I mean, it can't get rustier.
  2. Mr Efficiency
    Likes: 969, Points: 113, Legacy Rep: 702
    Phosphoric acid changes iron oxide into ferric phosphate ( I think ? ), which allegedly acts as a barrier, but obviously it needs to penetrate right into the rust.
  3. thudpucker
    thudpucker Senior Member
    I'm sure the Phosphate worked well on a Test Bench environment.
    The same stuff, in a Vibrating Fuel tank cannot bond well enough to keep Oxygen away from the metal. Cracks will show up and the Rust will continue.
    B&S wanted us to buy new tanks. Made out of the same stuff the originals were made of.
    How thoughtful of them!
