rudder's joessel formula
Discussion in 'Boat Design' started by fede, Dec 13, 2005.
  1. fede
    Likes: 2, Points: 0, Legacy Rep: 34
    fede Senior Member
    Hi Guys, I need the Joessel's formula to calculate the force generated by a rudder at different speeds and different angles.
  2. tspeer
    Likes: 290, Points: 83, Legacy Rep: 1673
    tspeer Senior Member
    C = (0.2 +0.3 Sin a) L.
    C= The distance from the front edge for the center of pressure.
    L= The whole length fore and aft.
    a = The angle of incidence.
    But since this formula predates the Wright Brothers, is only good for square planforms, and isn't all that good even for them - surely you can do better?
  3. Karsten
    Likes: 8, Points: 0, Legacy Rep: 33
    Karsten Senior Member
    The formula today used is
    L = cL * Rho / 2 * V^2 *A
    L = Lift in Newtons
    Rho = Density of fluid in kg/m^3
    V = speed in m/s
    A = area in m^2
    cL is the lift coefficient. For symmetrical rudders with infinite span the relation to the angel of attack is
    cL = 2 * PI * alpha
    alpha is the angle of attack in radians. This gets inaccurate at greater angles of attack. The maximum cL you can achieve is usually about 1.2 then the foil stalls.
  4. tspeer
    Jossel's formula has to do with where the center of pressure is located - in other words, the moment arm.
    The equations you present are for the lift - in other words, the force that acts at the center of pressure.
    And the formula you give for the lift coefficient is only for surfaces of infinite span. For finite span surfaces, you have to reduce the lift curve slope according to the aspect ratio.
  5. Karsten
    Fede was asking for "the Joessel's formula to calculate the force generated by a rudder at different speeds and different angles". Now that I know what the Joessel's formula actually is it is clearly not suitable to calculate lift depending on the speed and angle of attack. The formula I provided gives the lift as requested for an infintie span foil as Tom pointed out.
    Isn't the centre of pressure just at 25% of the chord for symmetric foils again with infinite span? It moves aft when the foil starts to stall.
