Henriko
Junior Member
- Joined
- Sep 26, 2022
- Messages
- Reaction score
- Location
- Finland
Hello folks,
Just a simple question, I have a standard sized small rowboat and have built myself a sailing kit, with rudder, leeboards, mast and sail.
Tested it today, sails like a dream, but of course, the upwind capability could be better - it slows down considerably=extremely slow. Of course it HAS upwind capability, but as we all know the wind needs to be strong enough to give the forward kick and if I'm not careful, pressing too much upwind, the wear and tear on the leeboards, sail and mast is considerably violent.
Does not bother me though as 180 degrees sailing is a dream as long as the wind is in your back.
So - I know the perfect alignment and position of the sailing components is: sail CE and the boat CLR and the leeboards are lined up vertically under eachother, preferably with the CE a bit forward in order to compensate the sail shape transformations by the wind. But if this perfect alignment of all three is impossible due to the mast location for example, what is better - to have the leeboards lined up with CE (means leeboards are way forward from CLR quite close to the mast, as the mast is located closer to the bow) or the leeboards lined up with CLR (means leeboards are way aft from the sail around mid-boat where the CLR is located)?
Anyone else here who has created an own sailing kit for a standard glassfibre rowboat (ca.3,8m)?
Appreciate any thoughts regarding this fundamental question when designing sailing kit.
