Rotate
Discussion in 'All Things Boats & Boating' started by BlueBell, Aug 25, 2021.
  1. BlueBell
    Likes: 892, Points: 113
  2. Ad Hoc
    Likes: 1,570, Points: 113, Legacy Rep: 2488
    A good example of running in seas/sea state that a vessel is not designed for!
  3. Mr Efficiency
    Likes: 1,039, Points: 113, Legacy Rep: 702
    Not an uncommon occurrence in the history of ocean racing powerboats. A case of where aerodynamic penetration is helpful, but hydrodynamic penetration isn't. How does it happen, well the boat flies through the air, re-enters tail first, on a down slope of a wave, and the boat rotates about that aft pivot point and dives into the back of the wave. It has killed a few people.
  4. hoytedow
  5. Mr Efficiency
    The slightly rockered bottom was alleged to help avoid such catastrophes.
  6. Ad Hoc
    Nope.
    Good seamanship and understanding the limits of the design does that.
  7. Mr Efficiency
    Of course racing is an activity that occurs at the margin of sensible and safe seamanship. I can see how the rockered bottom might help reduce the chances of "stuffing", by allowing the bow to rise more easily.
  8. Ike
    Likes: 454, Points: 83, Legacy Rep: 1669
    Ike Senior Member
    And the ocean wins again.
  9. Mr Efficiency
    You also have the factor of boats made as light as possible to go faster, being more liable to break. A sort of vicious circle, go lighter to go faster, and the faster and lighter you go, the more likely to break.
  10. Ad Hoc
    I was going to click - like -... but for some reason this feature has disappeared!?
    Anyway.. well said :D
  11. jehardiman
    Likes: 1,077, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    The ocean always wins... it is insidious and relentless..
  12. sdowney717
    Likes: 84, Points: 58, Legacy Rep: 274
    sdowney717 Senior Member
  13. DogCavalry
    Likes: 1,499, Points: 113
    DogCavalry Soy Soylent Green: I can't believe it's not people
    Maybe it's up on YouTube ?
