right propeller for my boat
Discussion in 'Props' started by urisvan, Sep 6, 2016.
  1. urisvan
    Likes: 5, Points: 18, Legacy Rep: 53
    urisvan Senior Member
    i lost my propeller while motoring in Caribbean. it is almost impossible to find propeller here but a friend is coming to visit me from USA and he can bring one.
    the problems are:
    1-time is limited he can come just these days so i need to buy it within one or two weeks
    2- my old prop is three blade,15" diameter but i dont know its pitch, it is old and nothing is stamped on it. and i dont know what to buy!
    any help will be appreciated, because time is limited looking forward to hear from you soon
    Regards
    Ulas
    Likes: 2,057, Points: 123, Legacy Rep: 2031
    What engine, what type and size of boat, displacement of boat, power of engine, reduction ratio of engine, outboard/inboard/etc., target speed, etc.?
  3. urisvan
    Thank you Gonzo,
    Engine:
    yanmar 2gm20, diesel inboard, long shaft
    reduction is 2.21
    rated HP 16
    Boat:
    long keel boat around 8000kg, 31 feet LOA, 25 feet LWL
    target speed is 6 knts, mostly i use the engine lower RPM and 5 knot is a good speed.
    Regards
    Ulas
  4. JSL
    JSL Senior Member
    If you give all this information to a propeller supplier/dealer or manufacturer they should be able to 'size' it correctly.
    or try the Victoria Propeller website, they have a propeller program you can use but it may have limitations.
  5. bit
    Likes: 1, Points: 8, Legacy Rep: 34
    bit Student
    15" x 7" or (15" x 8")
    Regards
  6. urisvan
    three blade or two blade?
    and does 14*8 three blade works too? because my aperture is very narrow. if i put 15" only half cm or one cm remains (like my old prop)
    Regards
    Ulas
  7. urisvan
    i have written ACME propellers but they are pretty uninterested to find a solution. i gave them the datas they need but they want the spesifications of my old prop. if i knew it why i would ask to them?
  8. gonzo
