Retro Runabouts
SC1
Senior Member
Joined
Jul 5, 2003
Messages
217
Reaction score
4
Location
Sweden
Here is a picture of the new Strand-Craft 22 Retro Runabout.
V8 powered , Jet- propulsion, Fiberglass hull.
You are welcome to give me feedback on the latest design.
www.strand-craft
Kurt Strand
Now You're cookin'!:D Great looking boat (and no outboard!)
Why not make it a complete boat by adding a CAM.A.PROPULSION Pivotal Drive.it would look just like they used to look but a lot more convenient to trail and handle,and save a lot of bent shafts,and so simple to install.No leaky glands on keelson.
Good idea. Please give me more info ?There must be a market for this propulsion system. With some new fresh design it could be looking very nice on classic styled boats.
regards, Kurt Strand
HELLO SCI..CAM.A.PROPULSION is a name given to a propulsion system where the drive unit rides behind the boat transom (weightless) or in a pod allowing the drive to lift straight up for trailering or when an object or the bottom is struck,with a cam like action,unlike an inboard/outboard which has to overcome the propeller thrust or run out of water before they kick back and up.Vessel Pivotal Drive shaft Mounting is the (Patent Title) which gives the ability to build a drive shaft for a boat which can be as basic as was fitted to old boats, or a very sophisticated unit which can be the usual sub-surface 20 degree shaft angle drive,surface drive with surfsce piercing propellers,a kort nozzle steerable or fixed or a shroud and also a jet or turbo drive.There is not just one way to build or any one scale or use for the mounting,it depends on the required use,but when the mounting is fitted all of these drives can be fitted and used..My photo gallery has some images page 6 and 7 showing testing early models and there are other images of a classic boat also fitted with Pivotal Drive.
Carlson meets Chris Craft? Chris Carlson Bueller Turbo Craft? 70 years of speedboating in a nutshell (or rather, thumbnail.) Would it trailer behind my PT Cruiser or Prowler? Leonardo DiCapprio as Gar Wood in "The Mariner?" Decay and Ebert give it two thumbs up.
Thanks, and the answer to all questions are: YES!!! :D
