Note: This feature may not be available in some browsers.
...- Muller-Graf series - for semi-planing catamarans with chine...
... catamarans around 10 m lenght, 6 ton displacement and 10 knots of speed..
10 knots on a 10m powercat is only just over the hump speed. So it would be best to either aim for displacement speeds of under 8 knots or go for mid teens as a minimum speed.
Hi all. There is some time we arfe working with this series and we get som values of the Residuary resitance - weight ratio negatives for centains Volumetric Froudes. Does anybody knows if perhaps, there is some printing error in the coefficients values. Any help, most welcomed. RegardsWhich is also available HERE.
But with these parameters, the M-G series is generally outside your scope. But may offer you some guidance in addition to the Molland paper.
see here for an example of one of my home built designs in that size range
www.sailingcatamarans.com
Can you test mine, SA-VPP Power Catamaran 1.1, based on Molland and al. results for Froude 0,4 to 1,0, and a connection with Holltrop for lower Froude < 0,4. It is a spreasheet application working with Open Office or Libre Office.I would be very interested if anyone knows of a better calculator for speed predictions for displacement situations.
Here in my Excel spreadsheet, you can see there are values for some Froude that they are negatives....????I've used them in the past and not come across this...
Can you post your numbers/data?
Thanks Dolfiman, I will check out with my data. We worked with Molland with good results for slow and medium speed. We are working with some high speed model with chine for easy and amateur construction...Can you test mine, SA-VPP Power Catamaran 1.1, based on Molland and al. results for Froude 0,4 to 1,0, and a connection with Holltrop for lower Froude < 0,4. It is a spreasheet application working with Open Office or Libre Office.
