Resin trap with T-connector?
Discussion in 'Fiberglass and Composite Boat Building' started by bjn, Jan 18, 2017.
  1. bjn
    Likes: 8, Points: 18, Legacy Rep: 16
    bjn Senior Member
    Hello,
    I'm looking at buying a vacuum chamber. Most of the ones I find has a T-joint with two ball-valves on top.
    Like this design sold on eBay Germany:
    http://www.ebay.de/itm/3-5CFM-1720R...723453?hash=item21114609bd:g:Ob4AAOSwIgNXp-Sx
    Similar one in the US
    http://www.ebay.com/itm/Vacuum-Resin-Trap-Catch-Pot-Stainless-Steel-2-Quart-/111823409916
    I guess that works for degassing resin. But I intend to use it as a resin trap with a catchpot inside.
    How can these chambers with a T-joint save the vacuum pump in case resin flows into the T-joint?
    I feel that the lid has to have separate connections for the hose to the pump and the hose from the vacuum bag, doesn't it? But I can't find that design on the German eBay.
  2. fly186
    fly186 Junior Member
  3. bjn
    bjn Senior Member
    Thank you for the confirmation!
    Building my own is an option. A good one. I always wanted to do that before, but I don't have much spare time for these things at the moment.
    Nice pdf! Full of good info.
  4. ebnelson
    ebnelson Junior Member
    That looks like more of a vacuum accumulator. The vacuum gage would not be happy with resin in it. The traps my co-workers use have the hoses go directly into the vessel where the holes can be drilled out after the resin kicks.
  5. jorgepease
    jorgepease Senior Member
    A very simple one is a 4 inch pvc with a cross T on top. The 2 horizontals are used for pulling vacuum on your part. The remaining vertical can go to a another cross T. One of the horizontals goes to the vac pump, the other to a bleed valve and the remaining vertical to a vacuum gauge. i did this with a 36" tall pvc and it sufficed for enough infusions to build an entire 22' boat.
  1. sunbelt57
  2. mrdebian
  3. John Slattery
  4. Mcdo2137
  5. John Slattery
  6. CajunBoater
  7. Bigtalljv
  8. weldandglass
  9. bucketlist
  10. IdahoBoats
