Replacing outboard motors with sail in the Marshall islands
Rob's boat is a little truck. Quick easy unskilled build, long-lasting modern materials, designed for cargo. Beauty is not on the list of essentials here.
Plenty of volume for cargo displacement.
Ambiguous feelings.
Great of course, that a sailing proa arised to replace the plastic utility motor boats, but...
Compare this flat-bottomed, rigid, boxy thing with the traditional Marshalese boats...
regards
krzys
Really ? Did you bother to read any of the background ? The design was developed to use the available materials and skills, to build a boat that fits a specific purpose.
You might as well come here and proclaim sailing is stupid, we should all be driving motor boats....
Of course ... sailing is stupid... :D
Yes, I did. I also sailed a flat-bottomed Wa'apa and more traditional, deep-V proas, and can compare their sailing abilities and seaworthiness. And I built a traditional-looking proa of 3 plates of ply, in 2 weeks, without wooden stringers and without glass fiber. It is in use for 12 years.
Rob did a great job, it's true. But what stopped him from looking at what the islanders were building and sailing before? They were not stupid!
regards
krzys
Please do.
Any pictures? Or a better description?
Thanks.
They most certainly weren't/aren't. However, they did not have access to the materials that we have.
I sailed on a traditional canoe, spent hours chatting with the guys who build, sail and race them and studied all the rotten ones scattered around the shore at WAM. I then took the good things from the traditional boats. The rig and the paddle steering. . Traditional canoes are huge fun and fast for what they are. But no way are they easy to build, light enough to carry up the beach, able to carry a ton of payload (without being at least 40' long), survive 20 years of abuse in the tropics, or sail higher than 110 degrees to the wind. These are the reasons traditional boats have all but disappeared.
It is easy enough to alter a traditional proa to get some of these attributes and numerous people do so. To get all of them, the result will end up looking pretty similar to the Mini Cargo Ferry.
Latest from the Marshalls is they have received $US20 grand to experiment with electric outboards and green generating and charging systems on the proa and cat, plus enough money to build the second mini cargo proa. Pics of the locals enjoying the 1st boat attached.
Progress on the 80'ter is pretty good, most of the pieces are built (8m tender, hulls, beams, rudders, telescoping masts, toy box), 'just' the assembly, painting and rigs to go. Lots of interest from around the Pacific, there are a number of test route possibilities.
What is that second small Catamaran with the twin rudders? Is that a rival design?
Sort of. Called a WAM cat as the guys at WAM designed it before they knew about Harryproas (not quite correct, but it is a long story, with a couple of strong personalities involved). There is some analysis of the 2 boats at https://www.changing-transport.org/...eaT_TechnicalAndOperationalOptionsCatalog.pdf The mini cargo proa is faster, easier to build (not an issue, those guys could build anything), has a bigger payload and used a little less material. Also caught more fish, but I doubt this is a design feature! However, I designed it for sandy beaches, not knowing all the sand has been used for concrete, so the beaches are coral chunks. Easy enough to fix, not sure if they will do so on the current one being built.
One of the guys who drew the cat (all the measurements come from a single piece of string divided into halves, thirds, sixths and quarters, clever) and oversaw the build has just launched his version of the MCF in Germany. Videos - Proas.is http://proas.is/342-2/
