I bought Nutmeg sailboat plans. This boat is a simplifyed version of Bolger's Featherwind that is 15.5' x 4.5'.
The hull panels are 16' long cut from 2 but-joined 8' x 4' plywood sheets.
Unfortunately, I live in Brazil, where the standard plywood is 220cm long (about 7' 2-5/8").
In order to avoid a second but joint in the panels I must reduce 10% the boat length. I can have this in one of 2 ways:
The first is to reduce the distance between stations 10% keeping all other dimensions.
The second is to cut the bow near station 2 adding a bow transom that could have the same angle of original stem. The hull has a big forward overhang (aft too) and this cut is supposed not to change WL, CLR, CE etc.
I would like to use the first solution as I don't like the apearance of a bow transom but I have read so many warnings about scaling plans that I am affraid it could not be a good idea.
What do you think about it?
Thanks,
Renato
Thanks,
Renato
