Midday Gun
Junior Member
- Joined
- Mar 21, 2019
- Posts
- 60
- Reaction score
- Location
- UK
Pretty simple question as per the title, if only the answer was the same!
So I realise this has been done to death and right now my eye are going square from reading all the websites / threads / other information on the internet on this subject, and the answer seems different everywhere I look.
I've attached a picture of the deck, in the highlighted areas the balsa core has been crushed by a combination of insufficient backing plates and overtightening the fasteners leaving the deck noticably deformed.
Fortunately the core elsewhere is still in good shape.
I want to replace the core in the damaged areas, and a couple of other spots where I will be putting deck hardware.
The easiest option is plywood which is pretty resistant to crushing, the other option is what builders do from the factory, solid laminate. However I've not seen anyone online doing anything other than putting new core, I've never seen anyone use solid glass in localised areas for deckhardware.
I plan to go in from the top and then redo the non skid afterwards.
So whats the current consensus on this? (If there is one)
Thanks!
Thanks!
