putty pump needed
Discussion in 'Fiberglass and Composite Boat Building' started by brokensheer, Aug 20, 2013.
  1. brokensheer
    Likes: 3, Points: 18, Legacy Rep: 14
    brokensheer Senior Member
    I know this is not the market place but I thought I'd toss this out here as one of you may have one laying around and might consider selling it! to use with a 5 gal pail
  2. tunnels
    tunnels Previous Member
    why would anyone need a putty pump !! of you need that much putty you have much bigger problems !! :confused:
  3. ondarvr
    Likes: 780, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    Many companies use putty pumps, the most common size is for 55 gal drums.
  4. brokensheer
    well the need is for pumping adhesive into a hull, to bond a stringer grillage,, not to fix boo boos
