Hello everyone,
I am designing an automatic robot boat that will swim around and clean surface of the water.
Currently no hardware is built, so every component is flexible. I need to select proper prop and motor for the boat.
The boat is really slow. I need to get 200-300g (2-3 Newtons) pull force from the motor+prop, and the boat should reach speed of 0.5-1 m/s. The boat is battery-powered, so I am looking for the most power effective solution.
I've been searching the internet for several days now and unfortunately can't get my head around of what approach should I take to select the prop.
I have a clear understanding of what pitch should the prop have. But how do I select its diameter?
Basically what I fail to calculate is: given selected prop, what torque is needed from the motor for it to rotate at needed RPM?
So if I want to get 1 m/s speed, I can take a prop with 40mm pitch and then will need 1/0.04*60 = 1500 RPM to reach this speed (taking out slip for simplicity).
But what torque will I need? Also, what role the prop diameter plays here?
Will be glad if anyone can help!
