I am trying to generate CAD model of propeller KA 4 70 in solid works and then later on I am trying to validate open water characteristics of propeller with experimental results using CFD. But I am having some problem with geometry of KA 4 70 propeller.
First of all I am creating 2D airfoil section and then I am using formulas in Carlton for converting it in 3 Dimensional geometry. I have below question.
1. I have attached the screenshot of formulas in Carlton. Does these formulas required 2D airfoil section to follow some convention like leading edge should be at (0,0) and trailing edge at (-c,0) where c is chord length ? I have also attached 2D airfoil section. Which airfoil section shall I use for these formulas?
2. Also, I have attached screenshot of Prop KA 4 70. As can be seen from the picture, generator line is not passing exactly through the center line of chord at each cylindrical section. But, I think that these formulas assumes that generator line and center line are coincident and hence has the term 0.5C in these formulas? How shall I consider this in these formula?
Thank you in advance.
