Prop thro transom
Discussion in 'Inboards' started by Canveysteve, Aug 18, 2016.
  1. Canveysteve
    Canveysteve Junior Member
    Hiya
    Would it be possable to put a prop thro the transom as whanting to in bord with a xld engine was thinking of engine so gearbox faces to the bow the chain drive down to the prop ?
    Likes: 2,266, Points: 123, Legacy Rep: 2031
    It is possible, but you will need to use a propeller designed to worked ventilated (surface piercing) to be efficient. What is an xld engine?
  3. Canveysteve
    I was toying with the idea of cutting keel / transom and adding a "box so the prop is under tbe boat will do a scetch later think it should work , its a norman 23 mk2 so normaly fitted with z drive or a outbord ( the xld is a 1.8 dies ford found in escort vans , fiestas ect
  4. gonzo
    The complication and high cost of marinizing an automotive engine is something you should consider. Unless it was a common engine used on boats, you will have to fabricate and machine many parts. Also, you will have to adapt marine type spark-protected electrics. Further, the fuel system will have to be modified to comply with regulations or a marine system installed.
  5. Canveysteve
    Lancing do the marinising for them but am concidering going keel cooling to keep costs down ( will try n make my own ) will use standard header tank and poss dry exhaust
  6. gonzo
    Planing hulls are not ideal for keel cooling. However, you could put one that is streamlined along the keel. I think that will not be cheaper than the standard heat exchanger though.
  7. Canveysteve
    Shurly it be cheaper than all the raw water pumps ect ? Plus side tbe engine shoud last longer , cant se to find anywhere selling keel coolers ??
    I remember my mates boat jad just a cooling pipe was1.3/4 dia that was it ! Never had a prob other than a lil leak
    Du think the box idea would be better thsn thro the transom
  8. gonzo
    On a slow boat, dragging a pipe is not a major problem. Planing boats will have two main problems: firstly, it may affect steering and trim plus create a lot of drag. Secondly, when the boat lifts, some of the pipe will be out of the water and the engine may overheat.
  9. Canveysteve
    Mine acording to the specs is a full displacment so should be ok cooling i coud put at the rear i gess?
  10. gonzo
  11. Canveysteve
    Cool a canal speed boat !!
