Prop Choice Help for Custom Electric Motor Pod
antimattercrusader
New Member
Joined
Dec 29, 2017
Posts
Reaction score
Location
Fort Worth
Hello!
I am new to the forum so apologize if this is in the wrong section! Anyway, I have a small business building unmanned boats for survey use. Typically, I use trolling motors or ROV thrusters for propulsion and it works quite well, but for this project I need something with a bit more power. I need to propel a ~60lb 1.5m flat bottom boat to around 8-9 knots. Doesn't sound too hard - but trolling motors lack the RPM range and propeller pitch, no affordable thrusters exist for this speed. So, I've built motor pods using a custom potted brushless motors, mounting tab made from plate aluminum welded to a pipe, and 3D printed hydrodymanic cover/mounting hardware.
Each pod has around a 2kw (2-3hp) output with a max RPM of around 7000. (Theoretically, of course RPM varies with load)
Unfortunately, I am not getting much speed at all out of this setup. Only about 3.5 knots @ 50a/1.4kw. While I had an issue with motor timing resulting in not achieving anywhere near top RPM - I feel it wasn't severe enough to justify the lack of performance. I am wondering if the fault is the propeller - The first one I tried is a Young's T-5W (Young's Die-Cast Aluminum Trolling Motor Props for Byrd & Lazytrol Electric Trolling Motors http://www.youngprops.com/byrd.htm). My guess is this propeller has too shallow of a pitch for this type of setup. Does anyone have any thoughts - and any idea of what type of prop I should use?
I went ahead and ordered one of these to try: https://www.amazon.com/gp/product/B01KFG5YR2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 but feel the diameter is a bit large.
Anyway, any input is greatly appreciated, especially with respect to propeller choice.
P.S. This boat is equipped with voltage/current/power consumption sensors, so I don't risk burning anything up by over propping.
PPS: This boat has two of these motor pods. It should be way overpowered.
Maybe you should try outboard propellers.
At what RPM are you looking to run the motor? 7000 RPM is far too high for efficient operation. At 2500 RPM, the optimal diameter is probably about 6".
If you can get RPM's down to between 500 and 1000, model airplane props are great.
Especially the adjustable pitch ones available.
How'd it go?
