Problem when creating Linked tank in maxsurf stability
jun
New Member
Joined
Dec 3, 2018
Posts
4
Reaction score
Location
japan
Hi~! i'm new at this forum
I made two tanks. And I want to connect this. But I can't choose a linked tank. I do not know if the settings are wrong. help me please.
Thanks for your help.
Thank you for the reply. I made a tank of different height. I want to calculate this.please.
Thank you for your advice.
But I did everything I could. I know there are two ways to calculate the tank.
First, select [HULL SELL] for the vessel and select [Internal Structure] for the tank...and seclect [Boundary Surfaces] in Stability(input)
(This way the surface can be calculated as a tank.)
Second is to specify the tank area as you say.
As I was saying, I think the first thing you should do is improve the definition of the hull. In a second stage, once the hull is correct, and not before, you can define the tanks as you think it would be better. I am of the opinion that defining them in HydroMax is better (the truth is that I believe that there is no other way to do it), although, of course, you can use auxiliary surfaces. See attached picture.
I solved the problem by making the name of the tank the same. Thank you.
