prob with gullco gbm-18 beveling machine
Discussion in 'Metal Boat Building' started by Kiev Fernandes, Nov 22, 2009.
  1. Kiev Fernandes
    Kiev Fernandes Junior Member
    while beveling, the machine pushes the plate out. it bevels only 20 or so mm and then the plate slides out of the teeth.
    NE SOLUTIONS
  2. welder/fitter
    Likes: 32, Points: 0, Legacy Rep: 423
    welder/fitter Senior Member
    gullco gbm-18
    A photo would help. Am I right in assuming that you have the gbm-18 floor or table mounted? And, you are feeding the material? I prefer the "bug" bevellers, like the gullco kat, great for out-of-position (in the field) cuts/bevels. I don't have time to read the specs/brochure. Does this unit have feeder rolls? I watched the video and know that I wouldn't be happy with a beveller rolling along the floor with no track to control it. I'd suggest you create a track, so the beveller cannot move away from plate.
    Best of luck!
    Mike
  3. Kiev Fernandes
    thanks we solved the prob some settings were not proper.
  1. steve123
