M&M Ovenden
Senior Member
- Joined
- Jan 15, 2006
- Posts
- 365
- Reaction score
- 80
- Location
- Ottawa
Hi Hildershavn,I think this is more suitable for steady-state tests. I am looking for an accurate way to measure pressures when driving at high speeds into waves etc. I have been looking at a pressure scanner, which is essentially a manifold with sensors from which a network of liquid filled tubes extent out to wherever you want to measure. Talking to the supplier, they admit that the length of the tubes and the liquid inside them will provide some dampening of the pressure, thus making it more suitable for steady-state.
The aircraft wing project I spoke about was on a jet fighter for dynamic stall behavior (very fast response time). The transducers were installed in the fairing to avoid any lag due to hose length, and set up as Dcockey mentions. We collected 1200Hz data which provided the detail of what was happening over the leading edge. I'm pretty it's possible what you want to capture, but the engineering effort will be about how invasive it will be to your candidate hull.
Mark
