Pop bottle style pontoon
Discussion in 'Projects & Proposals' started by parkland, Nov 30, 2012.
  1. parkland
    Likes: 6, Points: 0, Legacy Rep: 40
    parkland Senior Member
    How come pontoons can't be made like pop bottles?
    Pop bottles are insanely strong!!
    And cheap!!!
  2. Submarine Tom
    Submarine Tom Previous Member
    I guess you've never dropped one while unloading grocerys.
    They explode!
    It takes 71 two-litre bottles to make a size 42 polyester 3-piece suit.
  3. rwatson
    Likes: 265, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
  4. jonr
    jonr Senior Member
    What happens when the bottles get a few tons of barnacles on them?
  5. parkland
    No i meant like giant pontoons, not a bunch of bottle tied together.
    Picture a giant pop bottle the size of a pontoon, but made using the same or similar technique as making a pop bottle.
    I wouldn't be surprised if the strength to weight ratio is better than aluminum, and I bet they could take a beating a lot better too.
  6. rwatson
    The closest equivalent would be roto-moulded kayaks and small dinghies. You dont see them much bigger than ~13 ft due to the complexity of the moulds and the lower strength as they get much bigger.
    Everything larger is cheaper and easier to build from the more usual materials, including aluminum.
    Pop bottles arent all that strong in larger sizes unless they are full of liquid or high pressure gas - they get flattened out when you stand on them pretty easily at their current size.
  7. rwatson
    They sink, and then drift off to pollute more of the ocean.
  8. parkland
    I pumped one up to 40 PSI once and it was hard as a rock.
    1/8" walls and 5- 10 psi would make it uber strong!
  9. WestVanHan
    What happens when you get a leak?
    I fooled around pop bottle rockets years ago-cheap pops would go BOOM at 85,many around 125 and some to 140-150.
    Anything over 60 I'd say is getting risky to handle/be close to.
  10. rwatson
    yes, but they aren't UV stable, are only a few MM thick so you cant fasten stuff to it, are easily punctured by sharp objects.
    Other than that, they are perfect :rolleyes:
  11. parkland
    Well they could be thicker, and painted, or add a uv stabilizer to the plastic. :confused:
  12. hoytedow
    Likes: 193, Points: 73, Legacy Rep: 2489
    hoytedow Wood Butcher
    2 litre carbonated beverage bottle lids are tested to 100 lbs at the bottling plant. After that the lid blows of with explosive force. The bottles fail before that.
  13. upchurchmr
    Likes: 78, Points: 48, Legacy Rep: 579
    upchurchmr Senior Member
    Parkland,
    Do it, show us.
    If you don't want information don't ask the question.
    Just do it.
    The material never gets any better when you make it thicker or paint it or any thing else, unless you cover it with fiberglass so the fiberglass takes all the load.
  14. rwatson
    Yes, of course they could - then they would be like the roto-moulded boats I was talking about earlier, with all the weight, complex moulding problems I talked about earlier.
    Then, my persistent friend, they would not be competitive with aluminum, wood, FG etc as I also mentioned earlier.
  15. PAR
    Likes: 470, Points: 93, Legacy Rep: 3967
    Oh my . . . paper mache composite seems up next.
