Do you have some pictures and/or other info on that cat of yours?
I'd be interested particularly of any of your opinions about containing/reducing any of the wave slap that can occur under the bridge decks.
Bdeck wave slap is simple to avoid.
Minimum clearance at 6% of beam midship and citing
@Ad Hoc 10% at the bow.
There are some caveats.
If the “midship” clearance is further aft from the bow; this reduces it.
If you avoid massive sea states; there is less likelihood to encounter.
If you install a forward trampoline, a webbed one means the boat can tolerate a blast of water better.
On my boat, I also added two vee shapes. The bottom of the bdeck is a mild vee of about 4-5” per 4’3” each side. The front is also veed.
Prior to the bow extension design offered by
@Ad Hoc, the boat was pitching and the bdeck slammed one time in a nasty heaving boat wake.
Since then, no sea state has resulted in slam/shudder. I call it slam/shudder because the entire boat is affected by it.
Now, to be clear, my boat was 8.5” negative trim prior to the extensions, so it was way down and hobby horsing a horror.
The bow extensions keep the front of the boat higher sooner, if you will. So, while the 5-6%/10% rule is good general guidance, a longer distance to midships also helps.
A naval architect like Ad Hoc may have this pinned down to a harder science using length to midship.
This picture is best at hand photo, can’t really see the vees well. She sits on a lift aft end in so I can get another pic if I take a boat out. Maybe another day another thread.
