Planing Wheels
Discussion in 'Surface Drives' started by Colin Wilson, Apr 30, 2018.
  1. Colin Wilson
    Likes: 1, Points: 3
    Colin Wilson Junior Member
    PlaningWheels
    A lifting and propulsion device for amphibious use; consisting of a wheel like device with angled planing surfaces arranged around the circumference of the wheel such that when operating in water and the wheel is rotated the planing surfaces provide a lifting force directed downwards and a propulsive force directed rearwards thereby raising the associated watercraft above the surface of the water and simultaneously propelling it forward. When on land this device operates more or less like a conventional drive wheel on a land vehicle.
    fallguy likes this.
    Likes: 1,727, Points: 123, Legacy Rep: 2031
    There are several variations of that system. For example, search snowmobiles over water.
  3. SamSam
    Likes: 200, Points: 63, Legacy Rep: 971
    SamSam Senior Member
    You had this on here several years ago, have you tried it yet? Do the front end wheels get powered also? Reverse looks to be problematic, as does steering.
  4. jorgepease
    jorgepease Senior Member
  5. Doug Lord
    Likes: 349, Points: 93, Legacy Rep: 1362
    Doug Lord Flight Ready
    God I hate that noise! Stop them before they spread! Pretty cool tech, though......but still- throw a net over that guy!
    fallguy likes this.
  6. jorgepease
    yeah its cool but it can not get popular! lol ))
  7. Colin Wilson
    Likes: 1, Points: 3
    The model is 4 feet long - 4 wheel drive - 6 hp - 24 lb.
    What works best is a relatively large contact area with a good aspect ratio. Hopefully you end up with a high lift to drag ratio that increases with speed.
    Fast Track Amphibian is an example of the snowmobile approach however it pushes more water sideways than straight back and is mechanically complicated and inefficient.
  8. SamSam
    Have you tried it yet?
  9. gonzo
    Looking at the amount of parts and the possibility of getting snagged with debris in your design, a snowmobile seems much simpler. Also, those paddles will vibrate the fillings off your teeth on land.
  10. jorgepease
    I see the possibility of too much turbulence to even get a bite (back wheels) at high speeds anyway.
  11. Colin Wilson
    Likes: 1, Points: 3
    Something simple maybe be good in the snow as well.
  12. gonzo
    That won't work. The paddles need to be tilted the opposite way to get any traction.
  13. Colin Wilson
    Likes: 1, Points: 3
    I give up
  14. gonzo
    Why?
  15. Colin Wilson
    Likes: 1, Points: 3
    If you read my first post the paddles push the water downwards and rearwards. Resulting in a 45 deg. thrust vector pointing downwards and rearwards.
