Tad
Boat Designer
- Joined
- Mar 13, 2002
- Posts
- 2,332
- Reaction score
- 241
- Location
- Flattop Islands
I've got a puzzlah.....
28' Aluminum planing boat, VP 315HP DP outdrive, floating as shown in the drawing she weighs around 15,600 pounds. Apparently that's with 600 pounds of lead in the engine well to make her work slightly better. From the lines the boat looks fine, perhaps a bit narrow but nothing weird in the basic hull. She is massively overweight, apparently the original design was at 9000 pounds.
Now her performance....From about 18.1 knots (2700 RPM), if the throttle is advanced further she will heel to starboard about 8-10 degrees and trim flattens out(nose drops). As speed increases she then goes into a hard port turn and will not come out of it without chopping the throttle. This seems to be classic instability where she runs in equilibrium up to 18 knots, then drops to a lower trim angle where the bow is immersed and pulls her into a turn.
The question is how to fix this? I've suggested a new hull, that's not happening due to budget. The owner likes the boat alot and the weight can't easily be reduced. It's a tremendously overbuilt and overloaded boat. Small sponsons were added aft outside the chines, they are 5.5" wide and 12' long, that did nothing and may well be driving the nose down. I'm thinking about big lifting strakes forward tapering to nothing aft......
