Plane a double ender
Discussion in 'Powerboats' started by Inquisitor, Jun 12, 2010.
  1. DrCraze
    Likes: 6, Points: 0, Legacy Rep: 33
    DrCraze Junior Member
    I have given this much thought as well. My thinking is flush mounted trim tabs at each bow to act as phantom transoms. "Phantom Transom" thats what we should call them.:p
  2. DrCraze
    Seeing as you have light winds I would advise building a lee deck to counter the weight of the ama. It is what hundreds of years of R & D has come up with so give it a try.
  3. hoytedow
  4. Inquisitor
    Likes: 11, Points: 18, Legacy Rep: 155
    Inquisitor BIG ENGINES: Silos today... Barn Door tomorrow!
    Oh! Now it makes sense... about the lee deck.
    I'm quite enammered with the HarryProa design. It just makes better sense to me...
    It makes the alma the primary sailing hull and the living quarters (a lot heavier) the counter weight for the heeling. Basically you have the leverage of a trimaran when it is flying two hulls without having to carry all the extra structure and extra alma. So, in theory, I'm thinking, it should out run trimarans of similar size.
  5. hoytedow
    Probably so, but the correct word is ama, Get the l out of there.:)
  6. HakimKlunker
    Likes: 19, Points: 18, Legacy Rep: 146
    HakimKlunker Andreas der Juengere
    If you really intend to plane in reverse, please let me know when and where - - - so that I can be very far away from there :D
  7. daiquiri
    If we are talking about a powerboat, then the short answer is - yes, it can. But it has to meet several requirements:
    - it has to be light enough
    - it needs a little add-on at the transom.
    An example comes. This is a "gozzo", a very popular traditional boat of the mediterranean area:
    [​IMG] [​IMG]
    It is a double-ender, a pure displacement boat, originally equipped with latin sails. With the advent of IC engines, the sails were substituted with slow-reving inboard diesels (I can still remember waking up as a child with that relaxing "-pom-pom-pom-pom-pom-pom-" sound coming from the sea :) ), and later with fast diesels too.
    The latter engines, together with this modification at the transom (the first photo shows an add-on, the second one a design hull feature) alowed it to go beyond the "hull speed":
    [​IMG] [​IMG]
    though not so efficiently as a prismatic hull can (obviously). But again, the hull needs to be of lightweight construction - even a transom plate can do very little (or nothing) to help a heavy hull go over the hump.
    Finally, this is what a modern GRP gozzo looks like at full speed:
    I hope the photos are not too big for your screens. I wanted them a bit bigger to show all the details of this beautiful boat type. I really like the gozzo shape. Or maybe it's just a matter of memories from the childhood. :)
